Gear position sensor?
rix313
Has any one or does any one know if it is possible to obtain gear position data from the standard gearboxes? Is there a sensor retrofit that is possible? I have a DL1 data logger and Dash3 for my race car and would like to obtain gear position information?
winx
I have the DL1 and Dash 2 and after inputting the ratios it calculates the gear position from the speed and revs. Works perfectly for me, unless you need actual rather than calculated?
rix313
Ah brilliant thanks very much for the info! That's perfect.
