camber toe ect set up
Sx279
Post Wed Apr 15, 2015 4:41 pm
hi im looking to get my car set up soon for a track day I got coming up
I have got gaz gold coilovers front and rear, adjustable top mounts and eccentric bushes on the arms.
wear should I start with geometry camber toe in/out ect
any help would greatly be appreciated......
thanks....
milescook
Post Thu Apr 16, 2015 6:51 am
Hi, I started out with 0 toe and as much camber is the plates could give me - the seasoned guys will hopefully tell you that's not the way to go but it is a start. The thread about front end grip has some values but for me your main priority is choose some safe settings - as long as you're not wearing your tyres badly.
For the Gaz I went for the dampers from 75% stiffness so however many clicks you have (mine have different numbers both sides for some reason :( ) go about 25% of the way to soft. Height wise I went 26 cm from the collar to the start of where the hub carrier is welded on - not very scientific sorry! If you do that you need spacers otherwise standard basket weave wheels will rub the tyres on the coilover collars, so I had to go to 29cm. Rears I went 10.5 from the collar to the top of the dial.
Can't promise the above is optimal in fact I know it won't be, but it is driveable the biggest gains will be seat time getting used to the car. If you're newish to this I'd recommend a notebook, note changes and feedback, don't change too often and the biggest thing that helps is seat time.
Where are you going?
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Sx279
Post Thu Apr 16, 2015 12:56 pm
just lyddon for bhp but will be doing brands after that......
milescook
Post Sat Apr 18, 2015 5:25 pm
If you drive this slow at Brands you'll be fine :D
I did get faster with confidence but honestly seat time is one of the biggest helps.
Sx279
Post Sat Apr 18, 2015 11:54 pm
just start from 2:45lol i was waiting for the silver e46 to pass then i wanted to catch it and pass but slipped abit haha
rix313
Post Sun Apr 19, 2015 5:29 pm
For toe something like 1mm out on the front, keeps the nose responsive on turn in. With regards camber, you need to have the car on a proper flat patch and have the ride heights set first. As a rough guide you can set the camber based on your tyre wear. That's how I have done mine for the time being and I am getting really good even tyre wear.
