Compact rear callipers
mattxr2
Post Mon Mar 30, 2015 10:21 pm
Does anyone know if the compact callipers can be fitted to e30 arms. The pads I want to use are only listed for compacts and not e30.
I would assume they are the same but can't find any information on it
maggspower
Turbo Farmer Tractor Driver
Post Tue Mar 31, 2015 12:09 am
They can't be fitted tried a while back, but I cant remember why, disc offset? I'll check for you tomorrow, I have both knocking around.
However I reckon the pads will be very similar, so fitting the ones listed for compact may do the e30.
mattxr2
Post Tue Mar 31, 2015 9:51 pm
I think you are right, from what iv seen the compact arms give a wider track than an e30. I'll
Have to compare the pads or buy something different for the e30 callipers
Thanks :D
HairyScreech
Post Thu Apr 30, 2015 8:11 pm
Discs are larger as well so you would have to use a e30 bracket.
If you have a saloon you can use touring calipers for 34mm pistons
the z3 piston side might fit with e30 bracket, when i had them side by side they were very similar. Z3 piston is 36mm.
