rear brake upgrade suggestions please
Tedswagon
Thu Jan 16, 2014 10:00 pm
I have an R reg e36 compact with the original 318i rear brake set up. (5 stud on the E30 subframe and trailing arms.) The car is has an S50B30 engine fitted and some Brembo 4 pots from an 8 series up front. It is only used as a track day car so a rear brake upgrade is long overdue.
Suggestions please.
Thanks in advance.
Ronan.
rix313
Fri Jan 17, 2014 11:51 pm
Keri at WMS does his 2 pot rear caliper and larger rear disc conversion kit.
Tedswagon
Sat Jan 18, 2014 7:40 am
I've pm and emailed him but no reply. I'd like to see what alternatives there are. I can't afford an ap setup but heard there's a Porsche caliper which can be used.
maxfield
Sat Jan 18, 2014 1:40 pm
I'm fairly certain DanThe sells some adapters so you can run 540i rear calipers.
maggspower
Turbo Farmer Tractor Driver
Sat Jan 18, 2014 2:52 pm
maxfield wrote:I'm fairly certain DanThe sells some adapters so you can run 540i rear calipers.
The problem with that is getting a pair of e34 540i rear calipers, otherwise a good upgrade.
Yes I think Dan does the adaptors too.
Jimbob
Sun Jan 19, 2014 11:09 am
A caliper can also be used from an e32 750 and an e34 m5 3.6, there could be more but it's been a while...
Sun Jan 19, 2014 12:16 pm
They are getting a bit thin on the ground, but first thing to consider is the hydraulic balance between the front/rear and master cylinder, obviously the standard rears have a much smaller piston compared to a 540i for example
Tedswagon
Wed Jan 22, 2014 6:57 am
Thanks Dan.
Still no reply from Keri. Anyone know his contact details. I've tried email and pm with no reply.
Ta.
Tedswagon
Wed Jan 22, 2014 7:01 am
DanThe wrote:They are getting a bit thin on the ground, but first thing to consider is the hydraulic balance between the front/rear and master cylinder, obviously the standard rears have a much smaller piston compared to a 540i for example
What MC would you suggest. The car has the e36 m3 set up apart from the rear brake calipers which are the standard 318ti ones still. And I assume the balance would require rerouting the brake lines internally??
Tedswagon
Wed Jan 22, 2014 7:02 am
Wed Jan 22, 2014 9:25 am
M3 master cylinder and rear calipers will prob be as close as you can get to perfect with standard parts, would be worth checking the difference in the front calipers piston surface areas between the brembo's and the M3 to see how far out they are, would give you an idea on if you need a rear bias valve or not too
Tedswagon
Wed Jan 22, 2014 1:19 pm
Thanks DanThe, I'll look into the difference in surface area.
keri-WMS
Tue Jan 28, 2014 11:22 pm
Really sorry for not getting back to you - I've been snowed under and had a pretty nasty new year too. I owe a fair few people replies and am working through them, and in fact several are about E30 rear kits which is good as we normally do them in batches (being low volume in comparison to the front ones).
Just to confirm...I've got an E36 (325i) rear hub to play with (as well as E30 4-stud of course), but that isn't the same as you're talking about here with the compact?
bmw9818
Fri Jan 31, 2014 11:05 pm
ive just been searching through the threads, would a 535i caliper do? same as 540i i assume.. got a brand new one sitting here, unwanted part so rather than sending it back
Tedswagon
Sat Feb 01, 2014 9:54 pm
Wow, just logged on here amazed to see some responses, Tbh.
My second son was born on Monday morning so , haven't had a chance to do much.
The rear set up is a e36 318ti compact, standard, which as far as I knew is the same as the e30 and the z3? What difference would 4 or 5 stud make?
To bmw9818, I don't know if it would work or not. I'll have a look about and see if it's suitable. If you could pm me a price delivery included to Edinburgh that would be much appreciated.
Ronan.
Tedswagon
Sat Feb 01, 2014 9:56 pm
bmw9818
Which 535 is it off? Part number would be good too.
Ta
keri-WMS
Sun Feb 02, 2014 1:10 am
Congratulations! :cool:
The offset of the hub/flange might be different, not sure what else as I've not had one to hand to measure...
Tedswagon
Sun Feb 02, 2014 9:46 am
Cheers Keri,
Ah I see. Knew it would be too good to be true. I kinda wanted a bolt on system which would not require to much by way of brackets. Do you think there is any of your systems which could work?
Tedswagon
Sun Feb 02, 2014 10:11 am
Cheers Keri,
keri-WMS
Sun Feb 02, 2014 10:31 am
I might well work - I just don't know at the moment! :D
Tedswagon
Sun Feb 02, 2014 7:42 pm
keri-WMS wrote:I might well work - I just don't know at the moment! :D
My first trackday this year is 1st March, would like to get the brakes on and set up before then. What do you think? Is there any chance we could get something worked out by then?
Ta
keri-WMS
Sun Feb 02, 2014 8:22 pm
I've got the brackets and discs, but the calipers won't be here by then as I haven't even worked out how many I need if I'm doing a batch and it takes at least a month - sorry...! :( No point trying to do it if its likely to end up missing the date.
Is that a dealbreaker for you? :?
keri-WMS
Sun Feb 02, 2014 8:23 pm
PS - that's E30 brackets I mean!
Tedswagon
Tue Feb 04, 2014 10:55 pm
Right Keri, I've found out the e30 and e36 compact are the same - apart from the number of wheel studs.
It wouldn't be a deal breaker but I've two track days in march so sooner is obviously better for me. winkeye
keri-WMS
Tue Feb 04, 2014 11:09 pm
I'll try and get my mitts on an E36 Compact rear corner then....is E46 Compact the same do you know?
Tedswagon
Tue Feb 04, 2014 11:43 pm
Pass, I'm afraid "I know nothing"
keri-WMS
Tue Feb 04, 2014 11:47 pm
It's a good bet though methinks - if not I might find out the hard way!
Tedswagon
Tue Feb 04, 2014 11:56 pm
keri-WMS wrote:I'll try and get my mitts on an E36 Compact rear corner then....is E46 Compact the same do you know?
I've just looked on real oem and looks like different set up entirely. looks like the E46 compact has e36 rear axle.
E36 compact : http://www.realoem.com/bmw/showparts.do ... g=34&fg=10
E46 compact : http://www.realoem.com/bmw/partgrp.do?m ... 7653&hg=33
keri-WMS
Wed Feb 05, 2014 12:10 am
:o: Ah.
Never mind, I've got my eye on an E36 source so it would have been ok anway! winkeye
Tedswagon
Wed Feb 05, 2014 7:21 am
Having had a look on real oem looks like the disc on the standard e36 318ti compact is 272x10.
The e30 318is is 268x10.
The e30 325i is 258x10
The e30 touring is 258x10
The e30 m3 is 282x12
So what that tells us is the 318is is a baby m3 afterall. :mad:
I'm sure you know all that anyway.
jmc330i
Wed Feb 05, 2014 8:22 am
The iS has the same size rear discs as any other E30 (non M3). That's a mistake on Realoem, probably a typo by an iS owner :D
James
'91 325i Sport
'93 318i touring 16v
Gok
Tue Feb 11, 2014 2:59 pm
rix313 wrote:Keri at WMS does his 2 pot rear caliper and larger rear disc conversion kit.
I'm liking the sound of this. Few questions
How much is this kit? What diameter are the discs? 4x100 PCD?
Thanks in advance
keri-WMS
Tue Feb 11, 2014 4:13 pm
1 - £TBC, not 100% sure at this stage as it's a long time since the last batch we did.
2 - 290mm
3 - Yup, 4x100 and E30 bore (or any other bore you like)
I'll drop you guys some more info soon.
Tedswagon
Tue Feb 11, 2014 9:07 pm
I'm sure that'll fit the e36 compact. Only difference is the number of wheel studs.
keri-WMS
Mon Feb 17, 2014 12:43 pm
E36 Compact rear corner "on order"... :)
