Ive been busy this summer working on adding ABS to my track car. After some research and careful consideration I have decided to install the ATE MK60 DSC/ABS system from the late E46 models.
Below is a basic overview of the system components.
The system is fully programable and stand alone, which will bring a host of technological advancements over what is currently available for our cars. The nearest unit that comes close is the Bosch Motorsport ABS system. The additional advantage is the MK60 will output a speed signal to S54 and with a steering angle sensor you will have full DSC and ASC+T (traction control, a must with 340hp!!!).
Some more information about the MK60 DSC
The hydraulic unit consists of the following:
Ӣ Four inlet solenoids
Ӣ Four outlet solenoids
Ӣ Two changeover solenoids
Ӣ Two charge solenoids
It is designed to maintain the vehicles stability during:
Ӣ ABS braking regulation
Ӣ ASC+T traction control
Ӣ DSC for oversteer and understeer control (can be switched off and only ABS will be in operation).
Additional features are also programmed into the control module.
These features are:
Ӣ CBC - Corner Brake Control
Ӣ EBV - Electronic Brake Proportioning
Ӣ MSR - Engine Drag Torque Regulation
Ӣ ADB - Automatic Differential Brake
Ӣ DBS - Dynamic Brake System
I would like to propose to all those that are interested in a ”˜kit’ which will enable you to fit the Mk60 unit to any E30 with 4 or 5 stud suspension.
In the ABS kit you will receive;
2 x Front Speed Sensor adaptors.
2 x Master cylinder pressure sensor adaptors.
1 x Part Number List.
1 x Wiring Diagram + Instructions.
In the DSC kit you will receive all the of the above +
1 x DSC column kit.
1 x Programming for the E30 chassis.
The ABS Kit will retail for £199
The DSC Kit will retail for £399
Some photos - As you can imagine, a lot of time and work has been spent in building up this kit, the photos are taken in such a way to stop people copying the designs before any have sold!
The Steering angle sensor is still going through development, this is a solution one of my friends came up with and this is one we are going to develop further.
More photos and information to come.
Any questions, please ask away - To date, two DSC kits have already been sold!
Andrew
