Brake servo and itb's
driftwood
I've been looking at itb set ups for m20 engines. I don't see any brake servo vacuum connection on the ones I've seen. Is the servo not connected if itb's are fitted or am I not looking hard enough? Would the servo work properly if only connected to 1 intake runner? If a servo can't work properly using the vacuum produced from one intake runner, could a vacuum pump from a diesel engined car be used?
jmc330i
On my S50 I'm sure the vacuum pipe from the servo was connected to all 6 TBs via a runner connecting all 6 together. It ran along the top with the fuel rail.
Aftermarket ITBs may not have this, so one would need to be added.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Demlotcrew
Im pretty sure all the late S14 TB's only have one port on cylinder 4 TB for the servo. But they are 48mm, however I don't think the size of the throttle is what matters, just seems that the over all bore size would play a larger role in producing more vacuum.
driftwood
Well, mine is going to be a home brewed effort using a chopped 325i inlet manifold and gsxr 600 throttle bodies. Judging by the ones I've seen that have used a chopped manifold there doesn't look like there's room for a fitting on the inlet runner. Looks like I'll have to graft a vacuum pump from a diesel onto the motor.
Mikey_Boy
^^ Yep - absolutely right...Demlotcrew wrote:Im pretty sure all the late S14 TB's only have one port on cylinder 4 TB for the servo. But they are 48mm, however I don't think the size of the throttle is what matters, just seems that the over all bore size would play a larger role in producing more vacuum.
No need to go to the hassle of a vacuum pump - just make a hole the same size in one of the runners to accomodate the servo and you are good to go - you will definitely get enough vacuum that way...
harry_p
yep, a single throttle take off works fine, you'll need a decent one way valve in the system though or you can get a pulse through the pedal.
cheers,
harry
harry
UweM3
keep in mind how big the S14 brake booster is!harry_p wrote:yep, a single throttle take off works fine, you'll need a decent one way valve in the system though or you can get a pulse through the pedal.
driftwood
Is an s14 brake booster/servo a lot bigger? I would've thought that using a vacuum take-off on only 1 inlet runner would produce a weak vacuum or not keep up with demand if the brake pedal is pressed repeatedly.
Demlotcrew
No its not, the point Uwe is making is that the OP might have to run a smaller Booster for clearance etc.
I have never experienced any vacuum relates issues and mines only has one take off.
driftwood
Thank's for everyones input. I think I'll probably include a servo take tooff in one of the runners. And fit a 1 way valve in the vacuum hose.
harry_p
i only had the pulse thing on my metro when i first swapped the engine and had to bodge a hose (with no one way valve) temporarily.UweM3 wrote:keep in mind how big the S14 brake booster is!harry_p wrote:yep, a single throttle take off works fine, you'll need a decent one way valve in the system though or you can get a pulse through the pedal.
my only experience of the m3 setup was when the union popped out of the throttlebody and my scrawny legs struggled to give any noticeable braking effort
cheers,
harry
harry
