Can anyone recommend a good pressure gauge for checking pressures on trackdays? Seen these on ebay, are they any good or is it worth paying more for something a bit better?
http://www.ebay.co.uk/itm/DRAPER-19233- ... 2a1c781c02[/url]
Tyre pressure gauge
Silverfang
http://www.demon-tweeks.co.uk/motorspor ... sure-gauge
This is what I use when at work, ok not cheap, but there's a good selection here which is better than any ebay tat you can get, and will be correctly calibrated by a engineer, not some random in China.
A selection is here http://www.demon-tweeks.co.uk/motorspor ... durometers with some around the £35 mark which should be far better than anything on ebay.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Bristol_Jer
Thanks for the link, plenty to choose from on there
Think I'll probably go for one like this one unless advised not to:
http://www.demon-tweeks.co.uk/motorspor ... epth-gauge
The ebay stuff looks shite, the one I linked to was probably the best of a bad bunch!
Demlotcrew
This is really good, but on the large size, seems to be as accurate as the best of them.
http://www.ebay.co.uk/itm/GO-KART-LARGE ... 1e5df494ff
Bristol_Jer
That looks good
