318is e36 box
kipsy
Tue Apr 10, 2012 5:36 pm
Anyone fitted one to their cars with m20 motor?
GeoffBob
Forced Induction Specialist
Tue Apr 10, 2012 5:43 pm
Off topic I know, but this may be of interest to you Kipsy.
ftp://ftp.csir.co.za/DPSS/Landwards_Sci ... %20CH6.pdf
Will help make your synchro-rings last a bit longer :wink:
Tue Apr 10, 2012 7:51 pm
It sits at a different angle than the M20 if you didnt already know
kipsy
Tue Apr 10, 2012 8:41 pm
Yeh just been speaking to my bro (kevo) and he has one in stock to try which is nice. been on the gear calculator and it will be pulling a smidge over 100 mph at 6500 max rpm. Rallying all about stop go etc so not too bothered about high top speeds. I have had about 115 mph on events before but not often (6000 in 5th with overdrive box).
Gearlinkage tweek and possible prop change depending on what I've got.
Tue Apr 10, 2012 9:41 pm
It will defo make the M20 seem a bit more lively :D
kipsy
Tue Apr 10, 2012 10:32 pm
GeoffBob wrote:Off topic I know, but this may be of interest to you Kipsy.
Can't open the link sorry. Just going to stick a 2nd hand box
Rallyprep_UK
formerly Driftnething
Tue Apr 10, 2012 11:08 pm
I am under the impression that the difference between the e30 and e36 "is" box is only a different ratio. Is this correct ?
Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
alan1272
Tue Apr 10, 2012 11:18 pm
currently putting a box from an E36 318ti compact on to my m42. output flange on the e36 box has 12mm holes and the e30 box has 10mm, the two are not interchangeable due to different splines on the output shaft.
the e36 box is also slightly shorter.
e36 ratios are:
1 2 3 4 5
4.23 2.52 1.66 1.22 1.00
Rallyprep_UK
Tue Apr 10, 2012 11:20 pm
OK great, I wonder if this means the engine can move back a little bit :?:
Thanks for the good info !
Will
GeoffBob
Wed Apr 11, 2012 10:32 am
Right click on the link and select "save target as". It's chapter 6 of the book "Going Faster" as a PDF file, roughly 6Mbyte in size. Well worth a look.
kipsy
Wed Apr 11, 2012 1:00 pm
alan1272 wrote:currently putting a box from an E36 318ti compact on to my m42. output flange on the e36 box has 12mm holes and the e30 box has 10mm, the two are not interchangeable due to different splines on the output shaft.
e36 ratios are:
1 2 3 4 5
My brother has a 318is e30 with a 318is e36 box fitted. I'll have to quiz him later!
