Demlotcrew wrote:Geoff, why would i have trouble with the pedal box from ebay with the same size dual MC's as that of the stock E30 MC?
What i mean is, if i remove the Servo and use the Stock 22.2/17.46mm would that not have the same pedal ratio as the ebay pedal box using two MC's?
Now that is indeed a very good question Andrew. The short answer is no, and here’s why:
When you place two single M/C’s in parallel (next to each other) connected via the adjustable bias bar,
the force applied to the pedal is divided between the two M/Cs. For example, if the bias bar is set to 50:50, and you apply 10kg to a 1:1 ratio pedal (for example), then 5kg will be applied to each M/C.
However, when you connect two M/C’s in series (so that one pushes on the other) as is the case with a tandem M/C, then
the force applied to the pedal is applied directly to both M/C’s. For example, if you apply 10kg to the same 1:1 ratio pedal then that 10kg will be applied to both M/C’s.
What this means is that (assuming same sized M/C’s) you will require twice the pedal force with parallel connected M/C’s than will be required with tandem connected M/C’s to achieve the same hydraulic line pressure. To put it another way, dual M/C’s require twice as much pedal force to operate compared to the same M/C’s connected in tandem.
There are two ways around this problem for a given set of callipers and discs:
1) Increase the pedal ratio (although going from 4:1 to 8:1 wouldn’t be practical)
2) Decrease the bore size of the M/C’s to raise back up the line pressure for a given pedal force.
Demlotcrew wrote:I hope they sell it without the MC's
I believe that the M/C’s are usually sold separately according to your requirements.
Demlotcrew wrote:Also what would the small MC's do to the pedal travel?
Reducing M/C size always increases pedal travel. However, it is very important to realise that while changing from tandem to dual M/C’s doubles the required pedal force,
it also halves the pedal travel. And thus, any reduction in the size of the M/C’s in order to return the pedal force to normal will simply return the pedal travel back to what it was before.
My only concern in reducing the size of M/C’s is that they might hold insufficient fluid to operate the callipers. You will notice, however, that M/C’s intended for motorsport applications hold significantly more fluid between the piston and the bore than a tandem M/C from a road car. I would go so far as to say that a Tilton 75 series single M/C is nearly as long as any OEM tandem M/C. At least then you get a friendly warning if your fluid starts to boil in the calliper, instead of instantly losing your brakes (as can be the case).
