I'm using helper springs on my rear coilovers because the spring kept dislocating when it was jacked up and I heard it was an MOT fail but now have a new problem.
I put the helper above the main spring but now the cup at the top of the piston and the spacer between the helper and the main spring interfere with each other and I often hear them moving about when giving the car some stick. If I jack it up they almost always lock up in a silly manner when jacked back down. The cup and the spacer have almost no lip on them and this is what is making them dislocate when they contact.
Before I go to the hassle of swapping the helper to the bottom for a try I though I would ask what others have done.
Thinking maybe the best option is to get a longer main spring. I need longer ones for the front anyway as it's at its max travel now and it still a bit too low for me.
Rear coilover trouble
nickso
- Location: Go do that voodoo that you do so welllllllll!!
'88 e30 328i M52 track bint.
handpaper
Helper at the bottom is actually the correct location - it minimises unsprung weight when the wheel is unloaded!
Demlotcrew
I dont think thats quite correct, helper at the top eliminates unsprung weight.handpaper wrote:Helper at the bottom is actually the correct location - it minimises unsprung weight when the wheel is unloaded!
You could weld the main and helper together and get them powder coated?
This is not a bodge and many race cars have this done for the exact reason you mention.
In the photo above the spring is a tender NOT a helper but the principle is the same.
Andrew
nickso
Hmm, not a bad solution.
What's the difference between a tender and a helper? That tender looks a good deal thicker and longer than the helper I have on the car.
Demlotcrew
A tender spring is designed to produce a progressive over all spring when combined with the main spring.nickso wrote:Hmm, not a bad solution.
A helper spring adds nothing to the total spring or wheel rates and is only there to keep the main spring from falling off the perches/seats.
Today you can get progressive springs made in any size (ID/Length) and in any combination of spring rates.
I have a progressive spring rate on the back, quite a few race teams have had great success with this combination on the E30.
This is my rear, you can see the coils getting tighter towards the top of the spring.
Andrew
GeoffBob
- Forced Induction Specialist
The tender spring is on top, the main spring below in that pic. Notice how the tender spring has an almost flat cross-section to allow the coils to stack up on top of each other, after which the main spring takes over.nickso wrote:That tender looks a good deal thicker and longer than the helper I have on the car.
From Herb Adams' book Chassis Engineering:
"A study of the optimum spring rates for a car eventually came to the conclusion that the best spring rate is a variable one. We would like to have a low spring rate to absorb the road irregularities, and a high spring rate to absorb the larger bumps"
nickso
Cheers guys.
Andrew I notice you have a helper at the bottom of your spring. I take it you have no such issues with your setup?
Demlotcrew
No problems at all, not ideal for it to be under the spring but it works.
rix313
Did Curtis fit them or was this something you added Andrew?
Demlotcrew
I speced them, I have actually ordered more springs at a cost of £460!
these are too soft sadly.
Andrew
Andrew
