Clutch Explosion! Down Changed from 100mph and poof! M50 2.5
Jibberingloon
Post Fri Dec 02, 2011 11:30 pm
Has any had a clucth go pop and disintigate!
Was on track.....
4 lap of the morning....
Just spent 3 months of prep on car....
Bought it off a chap who had the car off the road for 2 years
doing 100ish.... and down changed while braking... lifted clucth pedal....
and complete clutch loss.
Got car up in the air when in the paddock, and could see friction material coming ou the small holes in the gearbox / engine casing.....
BUGGER!
Is this common?
Mark
Black_Potato
Post Sat Dec 03, 2011 10:14 am
New one on me....
Worth learning how to heal and toe if you don't already.
3x S14 Rightness....
Jibberingloon
Post Sat Dec 03, 2011 5:35 pm
I can heal and toe.....
But never had the cluch go poooooooffff on me before!!!!
Post Sat Dec 03, 2011 5:53 pm
Sounds like an luk to me!
Car still has dual mass iirc?
Z3I
Post Sat Dec 03, 2011 6:05 pm
Probably down it its not being used for 2 years. Very little use is far harder than very heavy use ith regular maintenance. Cant imagine the clutch and its facings were in the best of condition...
Jibberingloon
Post Sat Dec 03, 2011 7:15 pm
Not sure what the setup is on the M50 conv..... Will pick up a M20 flywheel setup perhaps, but will do some research ;)
Post Sun Dec 04, 2011 2:45 pm
You want M20 all the way, give me a shout if you want it lightening :wink:
Im looking to get a paddle clutch plate for mine now as its occasionally starting to slip again when hot/high revs :-x
Demlotcrew
Post Mon Dec 19, 2011 7:17 pm
You need to learn to rev match, thats the problem here.
I bet the pressure plate failed at the straps.
Andrew
mrLEE30
Post Thu Dec 29, 2011 2:40 pm
Demlotcrew wrote:You need to learn to rev match, thats the problem here.
Jibberingloon wrote:I can heal and toe.....
