Driftben wrote:thats one heck of a project you have there geoff, huge thumbs up for that one.
i think you have hit the nail on the head with the pedal box.
what do you think of this pedal box?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
i havent read all the MC thread yet to find out on MC sizes. still need to work that out
Ta, thanks Ben.
Those pedals look better, but obviously I have no clue as to the quality. My own pedals are by Tilton, and similar units are available from Wilwood. You'll pay for the well known brands though, but you can trust them.
I’d honestly suggest that you read through all the pedal box threads on here. I had an easy ride with my pedals since I had no exhaust manifold on the other side of the firewall to worry about. Theo was a similar case, but there are plenty of other examples out there of twin M/C’s mounted over the pedals (cylinders inside the cockpit) and twin M/C’s mounted on the left connected by the brake bar. Martin Pallot did quite a bit of work building his own pedal box on the right iirc.
If you do mount your M/C’s on the drivers side facing towards you just be sure that you don’t get a shin full of M/C in the event of an accident. You’ll also need to mount the fluid bottles where you can top them up without getting a mouthful of floor each time. Personally, I actually like the idea of the twin M/C’s mounted internally on the left. But beware the dual M/C Compbrake kit that bolts in place of the servo. This seems to have something of a failed reputation.
These two threads by Motorhole will likely be of some help to you:
http://www.e30zone.net/modules.php?name ... c&t=196955
and
http://www.e30zone.net/modules.php?name ... c&t=197857
Note the brake bias document that I indicate you can download in the first thread. That should help you with your calculations. If my ftp server doesn’t want to let you in I suggest coming back later. It can be cranky some days. There’s a handy excel spreadsheet somewhere in there too.
