right I'm sure a few of you will know this.. on my KW's i currently have a 180x100 spring on the trailing arm. Now to keep things the same if i was to run coilovers what spring rate would i need? i know it would be quite a bit softer but by how much?
rear coilover spring rates
BadDave
IIRC Gareth buses 400lb springs on the rear of his touring(not sure what spring length) with Leda coilovers
I use 275Lb springs 10 1/2" long on the back of mine for "normal" fast road use,with Gaz golds
chrisroberts
Thanks for the reply. The ones i have at the moment are 150kg or 400lbs. Mines probably a bit lighter than a touring. Might try a 300 lb one. see how it goes.
UweM3
150kgs = 400lbs??? are you sure?chrisroberts wrote:Thanks for the reply. The ones i have at the moment are 150kg or 400lbs. Mines probably a bit lighter than a touring. Might try a 300 lb one. see how it goes.
KW springs are usually in N
chrisroberts
Cheers Uwe, you will be right. I was guessing it was in KG as in my head 150N is around 850lbs which was making me think Bl***Y HELL. In fact they're 180N which is like 1000lbs?UweM3 wrote:150kgs = 400lbs??? are you sure?chrisroberts wrote:Thanks for the reply. The ones i have at the moment are 150kg or 400lbs. Mines probably a bit lighter than a touring. Might try a 300 lb one. see how it goes.
I'll have to get a tape measure out and measure from the pivot point to the inboard spring location and mount for the shock. Work it out from there and see how it goes.
GeoffBob
- Forced Induction Specialist
MarkT
350lb is a rate I have seen being used quite regularly.
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
chrisroberts
Thanks for the reply guys, and thanks for the link/lesson there Geoff, much appreciated. I have been following the R5 thread and must say it's bl**dy impressive to say the least! It's nice to know that there are some clued up people on here willing to help out!
Thanks again!
Thanks again!
