If I’m converting my rear suspension into a true coilover setup, other than strengthening the tower mounts, is there any other fabrication work that needs to be done to the frame/shell/subframe?
There will be a weld-in rollcage installed from custom cages UK. I’m not an expert in this field and this is my first track car build.
Thanks,
Bruno
true coilover preperation question
e21Jason
RPM sell offset top mounts so the coilover clears the inner wing/fuel tank breather
Also on rally cars they tens to reinfiorce the trailing arm coilver mount with a gusset.
Jason
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
m-heaven
Thanks Jason I will most probably get the trailing arm reinforced with a gusset.
For the offset RPM mounts can you kindly point them out on the RPM website because I can’t seem to find them unless they are the only ones that they currently have up for sale? Another question related to this offset thing, is that also required on a E30 M3 or is it non-M specific?
e21Jason
Hi
http://www.raceperformancemodified.com/ ... -Topmounts
Email them with what you want Jimmy is pretty hepful, and yes it is for all e30
Jason
Jason
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
RPM
