Air Ducts
spic
Post Wed Feb 09, 2011 8:38 pm
Are they any good on the front of the tech 2 sport or would i be better rigging up some myself ? what have you guys done ? pics would be good
Steve.
spic
Post Fri Feb 11, 2011 7:52 pm
Some one must have vented there brakes somewhere along the line .... winkeye
agent006
Post Fri Feb 11, 2011 11:09 pm
No idea on the tech2 but my SE ducts are fine for running proper ducting. Access is a bit tricky as they really need to go into the engine bay and back out again if you're still running the wheel well liners (which there doesn't really seem a good reason not to). Make sure you don't use ducting with steel hoops as water pools in it and they rust.
e301988325i
Post Sat Feb 19, 2011 2:44 pm
I've tried a few ducting ideas for road use with little luck TBH. For track just keep all the pipe work underneath the car, using the pipe itself as an inlet underneath the car. Imagine this but without the splitter.
I said:
e30topless said:
lock the wife in there
Mikey_Boy
Post Sat Feb 19, 2011 3:06 pm
+1 :thumb:
Unless you are endurance racing, I wouldn't duct cold air to the brakes directly - brakes do need some heat to work after all, getting the balance right is the tricky part...
Usual road set up with uprated discs and pads should be plenty for a 20 min squirt on track... winkeye
I run standard tech 2 front bumper with 330mm K Sport 8 pots at the front - no issues with overhaeting or fade (but then I might ot be trying hard enough!!) 8O
MillRat
Post Thu Feb 24, 2011 9:55 am
My setup - Flexi pipe runs from spotlight ducks in my Alpina splitter. Used a rectangular guttering downpipe joiner for the duct.
For cold weather, we shove a large sponge into the duct.
Cheers,
Michael.
spic
Post Thu Feb 24, 2011 10:18 pm
Thanks for the ^^^^^ posts. :wink:
agent006
Post Thu Feb 24, 2011 11:48 pm
That setup is very similar to mine, except I've still got the arch liners so the routing is a bit more complicated. I've also got similar size ducts on the rears.
spic
Post Tue May 03, 2011 11:06 pm
Ok so i have done the above with the venting but even on road after some spirited driving up to 4 or 5 round abouts within a 2mile stretch in town they still seem to be over heating(well i think they are !) the pedal still feels ok but im getting a lot of vibration/whoeing type noise with a little vibration through the wheel but only after heavy breaking repeatedly 4 to 5 times within a 2 mile stretch... breaking very hard every now and then dosnt realy cause any problems !!! Is it me ? am i driving too hard on the brakes ? or should i may be look at a caliper up grade ? Im currently running standard calipers with ebc yellows and drilled and groved discs ...
keri-WMS
Post Sun May 08, 2011 9:47 pm
The noise you're getting is normal for grooved discs, but if you're overheating the std size discs / EBC yellows you must be pretty tough on the brakes and the next step would be larger discs really.
The vibration through the wheel might be warped / overheating discs with uneven pad deposits, does the pedal shake/pulse as well?
spic
Post Mon May 09, 2011 10:24 pm
Na the discs arnt warped and the pedal dosnt vibrate nor is there any untoward feeling through the steering wheel ... This is the first time I have fitted these types of discs to the car so that makes sense so I think I will be swapping them for smooth discs as Im not happy with the noise realy :( Other than that I think your right I will have to keep my eyes open for a well priced brake upgrade :)
Stevin
Post Wed Jun 22, 2011 12:36 pm
Maybe the fact that the ducting blows directly onto the inboard face of the disc, and not into the centre vanes.
Thermal expansion will henceforth be difference between the inner and outer disc faces, which can lead to cracking, vibration and warping.
ross_jsy
Post Wed Jun 22, 2011 6:02 pm
It sounds to me like you are creating problems that don't exist. As Keri says, the sound is a bi-product of vented discs. Unless there was a noticeable decrease in braking efficiency I wouldn't be worried about it, especially on the road.
