Roll Cages? What are my options? Where from?
Jibberingloon
Post Wed Oct 13, 2010 6:18 pm
Looking to get a Roll Cage for my new toy.
What are the options available?
And where can i get a cheap one?
Regards
Mark :mad:
martinpallot
Post Wed Oct 13, 2010 8:21 pm
No such thing as a cheap bolt in cage anymore tbh. Even the wanky OMP ones are 500 odd quid now. Various weld in options but the price rises sharply unless you can fit it yourself.
Either way, fitting a rollcaeg should just involve bolting it in. Proper spreader plates should be welded at the feet or it will just push through the floor when rolled.
Driftben
Post Wed Oct 13, 2010 8:30 pm
Well you can get weld in cages for around £400 - £500 which are abit more involved than a bolt in cage? I'll see if I can find a link.
Mean while have a swift peak on google for cages. Abit of research and there quite I few about.
I scraped the cheap option and went for a multipoint cage from custom cages. £850.
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Jibberingloon
Post Thu Oct 14, 2010 2:24 pm
If you can fire me over a link that would be great ;)
The more info the better
Driftben
Post Thu Oct 14, 2010 2:34 pm
No problem when I get home i shall have a quick look and try and find the link.
6pot wilwoods front
4pot Porsche rear
zaust
Zone day release
Post Thu Oct 14, 2010 2:40 pm
The £500 omp ones still need painting and will end up costing more. Saftey Devices 6 point bolt in is the best option @ £750 and mostly self fittable.
M30 Tech 1 Touring on gas.
speedsnake74
Post Thu Oct 14, 2010 6:32 pm
Jibberingloon
Post Thu Oct 14, 2010 6:52 pm
Hmm in that case I know the Safety Devices seems a good shout ;)
Cheers for the info. :cool:
Driftben
Post Thu Oct 14, 2010 10:06 pm
6pot wilwoods front
4pot Porsche rear
Black_Potato
Post Thu Oct 14, 2010 11:31 pm
The cheapest one I would rely on is the saftey devices 6 point, the multi point next and then full weld in cages even better.
Driftben
Post Fri Oct 15, 2010 5:37 am
To be honest I would rather rely on a weld in multi point. Only due to my preference though after seeing some bolt in cages.
6pot wilwoods front
4pot Porsche rear
si-
Post Sun Oct 17, 2010 8:58 pm
anyone got anymore places to get cages from, as im also in the market for one and am in the middle of doing the reaseach the more places to try the better!!
Mikey_Boy
Post Sun Oct 17, 2010 9:41 pm
+1 Safety devices bolt in as a bare minimum.. Pretty easy to do as well (what I currently have) Weld in multi point the best (what I want to upgrade to).. What price do you want to put on your safety in the event of an off?
Would you buy a cheap helmet...? :mad:
Cheers,
Mike
tha881
Post Sun Oct 17, 2010 10:11 pm
si-
Post Sun Oct 17, 2010 11:15 pm
Mikey_Boy wrote:+1 Safety devices bolt in as a bare minimum.. Pretty easy to do as well (what I currently have) Weld in multi point the best (what I want to upgrade to).. What price do you want to put on your safety in the event of an off?
Cheers,
Mike
im not asking for cheap......
what are the differences that people have found between the omp and saftey devices cages??
Mikey_Boy
Post Mon Oct 18, 2010 8:53 am
Ah I see...! :surrender: Fair enough - I found the safety devices cage pretty easy to fit (all the bits came and it had good instructions) if I am honest and a good fit to the shell as well. Also found the optional harness bars very handy.
Trouble is, once you fit a cage and the handling improves 'cos the shell is more rigid, you may find that you want a bit more and hanker after a weld in cage!
Can't comment on the OMP stuff, but good luck with your hunting!
Cheers,
Mike
Driftben
Post Mon Oct 18, 2010 8:46 pm
Mikey_Boy wrote: Would you buy a cheap helmet...? :mad:
i would haha, paper mashe helmet anyone
6pot wilwoods front
4pot Porsche rear
Motorhole
Post Wed Oct 27, 2010 11:07 am
Would also recommend Northwest RS Centre - they bend and fit their own rollcages from CDS following MSA blue book regs. Just got a 6-point with harness bar welded into mine :wink: reasonable too.
si-
Post Wed Oct 27, 2010 11:12 am
price perhaps?
Donnystreeterroist
Post Wed Nov 10, 2010 8:17 pm
Whats the saftey devices cage like to fit? any box section's need to be welded in for it to bolt to??
i have one in my mini and was very impressed with the fit and quality of it
any pics of where it mounts to E30 would be good if anyone has any?
