RPM Camber plates...help?
tim_haynes
Post Thu Sep 23, 2010 2:42 pm
Hi all,
Just a quick question, to achieve maximum camber with the rpm plates do you have to take out one row of the cap screw bolts in order for you to slide it over more? Is this dangerous, dont want to run with just one set of cap screw bolts.
Thanks,
Tim
RPM
Post Thu Sep 23, 2010 4:39 pm
Hi Tim
Run with 2 sets in the back 2 holes (4 in total)
I'll email you a pic shortly showing what I mean
Do not run with just 2 screws in total!
Jimmy
GeoffBob
Forced Induction Specialist
Post Thu Sep 23, 2010 4:44 pm
Tim, if RPM's product works the same as the camber plates I bought locally from Koni SA, then as one pair of holes dissapears, another pair should emerge. In other words, you should have no problem keeping all four cap screws in place, regardless of what camber setting you choose.
tim_haynes
Post Thu Sep 23, 2010 10:13 pm
Yeah no worries guys,
Was a stupid question, I have them set on maximum, but dont worry all 4 bolts are in place still!
