Andy325i wrote:
Thanx for the replys guys
I don't get why the 4 door is stronger, are you saying they braced behind the rear seats? could this be done to a coupe? Thinking the only thing the coupe is missing is the tops of the front doors?
Andy
4 door e36 is stronger because it has a fixed rear bulkhead, which effectively makes the 'box' that is the shell smaller, and less likely to flex. it's a simple way to add a lot of torsional strength. all e36 coupes have folding rear seats, and hence no rear bulkhead.
supertourers changed to 4 doors to fit the rules of the time, which changed to having to use a 4 (or 5) door vehicle
start with a 4 door and weld up the rear doors and you have an even stiffer shell as the smaller front door openings alone will allow less flex than the large coupe openings.
although, if it's going to be a track car and youre adding a cage and other bits and bobs i doubt whether you start with a 2 or 4 door would make that much difference to the final stiffness
