Wheel and tyre sizes ...
spic
Post Sat May 22, 2010 9:00 pm
Hi Folks... Whats the best size wheels for a coupe 325 which is going to be used on the track ? i have the standard 15 " bbs wheels on the car at the moment but im thinking when i buy new track tyers should i stay with the wheels i have ?
Any advice most welcome
Thanks.
Post Sat May 22, 2010 9:22 pm
Whatever works best with your suspension setup, or offers best tyres for you..
15's with 205/50 will work well
spic
Post Sat May 22, 2010 10:00 pm
Running standard sport suspension at the moment...
agent006
Post Sat May 22, 2010 10:21 pm
I run 15" with 195/50 tyres as they're so much cheaper than most other sizes.
djs325
Post Sun May 23, 2010 2:38 am
7Jx15 Rims. 4x100 PCD. 57.1mm Centre Bore. Normal (original) offset is ET25, but many people are happy with up to ET15. We run a 205/50R15 Semi-slick Yokohama in Australia, the Americans run a 205/50R15 Toyo in SpecE30 on the same size rim.
E30racing.com.au - Like Production BMW Cup, but upside down!
spic
Post Sun May 23, 2010 8:13 pm
whats the widest i can go on the standard 15" bbs crossspoke wheel ...
BMracing
Post Mon May 24, 2010 11:51 am
215, but you wouldn't. It won't do anything for the handling if the tyre width exceeds the rim width.
Max
djs325
Post Mon May 24, 2010 3:10 pm
205 is all you need.
