im after pics of how you mount your 5/6 point harness' to blue book spec. 18 point cage has a harness bar so that is not a problem though.
cheers in advance,
ross
Could i see some pics of your harness mounts?
ross_jsy
cragles
This is the passenger side in our race car (drivers side the same)
You can see where the two groin strap eyelets are fitted and also where the tunnel side lap belt eyelet is. The sill side eyelet uses the original seatbelt position threaded hole.
Apart from this last one, the other 3 all use the proper eyelet spreader plates
pbmwc race car site
www.team156.co.uk
www.team156.co.uk
