First track day
Tedswagon
Hi all I have been invited on a private track day at knockhill. Only 20 cars for 2 hours.
My car is a standard 325i 1988 Reg coupe. I have replaced all of the suspension with standard springs and shocks from a sport.
My question is I can't change it to a track car as I need it on the road. I have to replace the front pads and disks, what should I get? Using the existing calipers.
Another question is there part worn track tyres for sale but these are 195 55 R15, would they be ok on 15" cross spoke BBS alloys? Currently 205 road tyres on the BBS. Which would be better on the track?
Any other advice welcomed.
Tedswagon
I also have a set of MIMs with good yoko road tires on them? Would they be better?
http://www.e30zone.net/modules.php?name ... c&t=160352
mattrs
Ebc yellow stuff front pads (demon tweeks) and if the discs and rear pads are reasonable then treat your self to a set of r888's about 200-250£ and worth every penny!
Enjoy your day mate!
e21Jason
Borrow my car
For your first day just pads, hoses, fluids as KH is hard on brakes I cooked the road pads in the m3 2 weeks go in the wet in 10 laps
Stay away from sticky tryes also to much grip, just good road tyres
and can i come
Jason
only joking about borrowing the car
and can i come
Jason
AlpineAde
You don't need to. You've got nice fresh suspension in it and all you need are some decent pads and good fluid (otherwise you'll run out of brakes). I run EBC Yellowstuff pads and find them very good indeed. I also run Motul RBF660 brake fluid ( a little overkill) or AP Racing 600/650. Both are very good ~ though not the most expensive stuff you can get. Castrol do that one, I believe.Tedswagon wrote: My question is I can't change it to a track car as I need it on the road.
As long as your car is mechanically sound, drive within your limits and pay attention to traffic and track conditions you'll be fine and have a lot of fun.
EDIT: and as above, good road tyres are fine. No need for anything sticky.
Tedswagon
Cheers all, I'll get some yellow stuff pads, see how the disks are and I think I'll go for the braded hoses on the group buy section if there are any left!
Come on Jason, pretty please
rosscoe
Alright m8
As said knockhill is VERY hard on brakes, at the very least change your fluid, to summin like ATE Super blue, it's not the most expensive but i found it well up to the task wen i had it in the tourer, and its the only fluid that i ever use.
Its a good little circuit to really learn your and your cars limits, just watch the brakes tho!
cheers
Tam
cheers
Tam
keri-WMS
On standard calipers its probably a good idea to keep a small bottle of your favourite flavour of fluid handy so you can quickly bleed the brakes if you do boil them.
Let them cool first of course!
billgatese30
Thats just the reflection from Gareth's hair causing a false readingkeri-WMS wrote:On standard calipers its probably a good idea to keep a small bottle of your favourite flavour of fluid handy so you can quickly bleed the brakes if you do boil them.
gareth
soon after that pic, i managed to boil my fresh ATE super blue fluid.
that's 427°C, not 427°F by the way... h h h hot!
of you're intending on using the car on the road most of the time, i'd go with EBC reds as they do work well from cold despite hanging on very well when on track.
keri-WMS
billgatese30 wrote:Thats just the reflection from Gareth's hair causing a false reading
rosscoe
FCUK me..gareth wrote:soon after that pic, i managed to boil my fresh ATE super blue fluid.![]()
gareth
i missed that last night. you arsebillgatese30 wrote:Thats just the reflection from Gareth's hair causing a false reading
a 1400kg (maybe 1320kg with the seats etc out) 220bhp M30 powered touring, rounds brands hatch.rosscoe wrote:**** me..gareth wrote:soon after that pic, i managed to boil my fresh ATE super blue fluid.![]()
that's 427°C, not 427°F by the way... h h h hot!...How'd you manage to boil that stuff.....wat track were you on?
it took some doing and a determined 15 or 20 lap stint though!
Tedswagon
Maybe it's just me but I can't seam to find Red stuff pads any place for the 325i E30. Just the Yellow ones!gareth wrote:of you're intending on using the car on the road most of the time, i'd go with EBC reds as they do work well from cold despite hanging on very well when on track.
Been to Demon Tweeks and EBC. Am I missing something?
Jon_Bmw
- Dangerous when thinking
Usually, you just replace the last digit with the colour of pad you desire
I.E Y with R.
So it might be dp4473R ----THIS IS NOT A REAL E30 number!
I.E Y with R.
keri-WMS
Have a peek here, we do them: http://www.e30zone.net/modules.php?name ... 53#1287153
Tedswagon
I've already read that thread and I'd love to put a set of those WMS 4 pots on my wagon but unfortunitly I can afford itkeri-WMS wrote:Have a peek here, we do them: http://www.e30zone.net/modules.php?name ... 53#1287153
How much would you want for a front and rear set of the red pads and will they fit the standard calipers? Will they be ok on standard vented disk? I'm pretty sure the calipers are the standard ones, not the girling ones! Oh yeah its a 325i abs. Not sure if that matters!!
keri-WMS
Tedswagon wrote:I've already read that thread and I'd love to put a set of those WMS 4 pots on my wagon but unfortunitly I can afford itkeri-WMS wrote:Have a peek here, we do them: http://www.e30zone.net/modules.php?name ... 53#1287153
How much would you want for a front and rear set of the red pads and will they fit the standard calipers? Will they be ok on standard vented disk? I'm pretty sure the calipers are the standard ones, not the girdling ones! Oh yeah its a 325i abs. Not sure if that matters!!
As far as I know the pads are the same for both front calipers, and as long as you have vented front discs (not solid) and discs rear (not drums) then it should all fit, I don't think ABS comes into it.
Tedswagon
Had a great time throwing it round KH, brakes held up well. They were given a good test and I now have blue disks, think they got quite hot!! Really want to do it again.
Here are a few photos.
Running wide as I spent too much time looking in my mirror at the yellow E36 closing in as I braked for the hairpin!!
Tedswagon
Here is a film from a track prepared E36M3 - I show up for a lap about 1:15!
[youtube][/youtube]
[youtube][/youtube]
320Touring
This Yoke looked none the worse for its adventure...
got me wanting to try an e30 on track now...
