Exhaust Views?
tim_haynes
Post Mon Oct 12, 2009 9:32 am
Whats the view on what size the exhaust should be for track use 325i's? is 2 pipes into 1 better or what?
I currently have a wildcat 6 branch, going into two 50mm pipes with a y piece into one 65mm.
Is that right, or should you run two pipes the whole way?
e301988325i
Post Mon Oct 12, 2009 7:50 pm
one pipe is good, two pipes of the same volume as one large one weigh 50% more than the single system!!!
I said:
e30topless said:
lock the wife in there
