well after having a pair of Corbeau seats in the garage for over a year i puchased some sub frames, genuine, to fit them. So one seat doesn't even fit on the frame and the drivers only locates on to the two bolts and one of the rear bolt holes, the other is about 4 mm out. Anyone else had this problem, am well hacked off after spending £160 on them ! The driver's seat is not so much of an issue as i can just widen the hole put the passenger frame is a mile off fitting the seat.
Still, plenty of time to get it sorted for Silverstone on 21/11.
