Alignment..
Post Tue May 26, 2009 10:32 pm
Where do you get yours done? I have adj front and rear camber/toe.
Or what sort of figures should I be looking for? I was thinking M3 settings with about 1.5/2deg rear, 2deg front
d6dph
Post Tue May 26, 2009 10:47 pm
Supertyres in Maldon have a whos-ya-daddy Hunter laser jobby. Chunk had his MR2 done there & it's really comprehensive.
UweM3
Post Wed May 27, 2009 6:17 pm
Jhonno wrote:Where do you get yours done? I have adj front and rear camber/toe.
for the front get your toe adjusted with the camber mounts in STOCK position. Setting to neg camber later will not alter the toe in a negative way.
The rear will be more of a "how much can I adjust" rather "how much do I want" adjust question. I do believe there is only limited adjustment available with these bushes and depending on how much your car is out of spec you may need to settle with what can be achieved.
Much more import IMHO is to get the rear toe right (--> at least equal and the rear axle line perpendicular to the cars axisif possible)
Good luck and keep us posted
