What LSD oil for track days?
Lloydie38
Post Thu Apr 30, 2009 9:12 pm
Hi,
Please can someone advise me as to the best Diff oil to use for my diff on the 325 track car, It does take a hammering so decent stuff is required - also what cost should I expect to pay....
Lloydie
fuzzy
He who sleeps with "Gingers"
Post Thu Apr 30, 2009 9:17 pm
mine takes a serious hammering and ive only used main dealer lsd oil with no problems so far. the diffs been in it for 4 years now since the engine conversion.
Ziggy
Post Thu Apr 30, 2009 9:18 pm
Castrol Saf-XJ - you'll need two of these
http://www.opieoils.co.uk/p-736-castrol ... icant.aspx
shorty73
Post Fri May 01, 2009 3:13 pm
Ziggy wrote:Castrol Saf-XJ - you'll need two of these
That stuff is superb. Got a shelf load of it.
See us in www.racingsaloons.co.uk helped by,
alloyproducts for alloy fabrications
www.motorsportoils.co.uk for Lucas oil
www.zeroexhausts.co.uk for the noise
MTech 07831831846 for an engine!
Theo
Post Fri May 01, 2009 7:53 pm
I use the significantly cheaper castrol B373 without any problems, alot of rally heroes use this fluid for clutch type LSDs.
Chris-W
Post Fri May 01, 2009 8:02 pm
Another vote here for B373, especially if you plan on changing it more frequently.
mk1nuts
Post Wed May 06, 2009 2:48 am
chris-w why b373 especially if he plans the chnage it more frequently does this stuff need to be changed regularly??
and whats the difference between the two mentioned above??
i think i need my oil changed as my dff is noisy? why does it get noisy??
rix313
Post Wed May 06, 2009 10:25 am
mk1nuts wrote:i think i need my oil changed as my dff is noisy? why does it get noisy??
Good question that. I imagine it has something to do with worn gears/plates inside the diff. Certainly doesn't idicate great health. Thats what I'd suspect, but a good answer should definatly be added to the Wiki.
With regards differences between the oils. The don't seem that different on the face but the B373 is about £5 cheaper. The more expensive one is quoted "Castrol SAF-XJ is also specifically designed for BMW differentials including the Z3 limited slip differential."
furbster
Post Sun May 10, 2009 11:46 am
I use Silkolene BOA 90 LS High Performance Gear And Limited Slip Differential Oil
This is only to be used with LSD though.
Available from opie oils.
Lloydie38
Post Wed May 20, 2009 9:41 pm
I decided to buy the Castrol - as it's the isle of man I had to order it in, but as the diff has been completly rebuilt it deserved some quality liquid...
We have the TT races in a few weeks and the mountain road is run for 12 miles one way, after the bike racing...Imagine the best twistie road and great straights, you can use both sides of the road, NO SPEED LIMIT, it's quality especially overtaking bikes on the outside around the bends....Guys you MUST come over here, it's just the best.. :D :twisted: winkeye :mad: :cool:
