best spark plus for track days..?
dph500
Post Sat Feb 28, 2009 9:05 pm
e30 325i, used just for track days. Which spark plugs are best? Does it really matter? Waht do he racing guys use?
kimbo
Post Sun Mar 01, 2009 9:45 am
If the motor is standard, then I'd use standard plugs under most circumstances.
If you're running for a long time at full chat on a hot day, then you could go one range colder (i.e. higher number on plug IIRC) but this may cause fouling on cold days / low revs.
Just look at the plugs after a run and as long as they're not scorched white on the electrode, it's OK.
If it aint broke - don't fix it! :)
Kim.
