Alritee folks
Am lookin for a roll cage for the tourer,and am kinda drawn towards the custom cages M3/99 one,has anyone on here had any experiance of these cages,as in any problems wi them,or am i better lookin elsewhere for a cage
cheers
tam
Custom cages roll cage
rosscoe
ROC
tam,
drop northloop (Gary) a pm. He had one fitted into his car and will be able to tell you all about it.
Cheers,
Rich.
Cheers,
Rich.
kimbo
Never done one in a BMW but installed one of their T45 multipoint cages in a Mk4 Golf a while ago.
The tubes weren't the best fit ever (main hoop was 50mm too wide to fit in the car) and the 'shaped' ends needed loads of work to make them right.
They are top cages though but my advice would be to get them to fit it - it really is a git of a job unless you're a very experienced welder!
Kim.
Kim.
stratos
Yes the tubes were generaly too long and needed cutting . But the bends were in the right place !
318 is.
Ray268
I have used them in my last two cars both fitted very well, you will need to cut to length and be handy with a welder.
Regards
Ray
Regards
Ray
nickso
- Location: Go do that voodoo that you do so welllllllll!!
tam,
why not try this lot. at least one zoner has used them and was impressed, think they might be mates though. im pretty sure i will be using them later on in the year unless i hear any bad feedback.
pretty local to you and their prices seem on a par with a customcage job.
http://www.chizfab.com/services/rollcages/
'88 e30 328i M52 track bint.
e21Jason
Kyle
At chizfab has my e21 at the moment for a cage it will be there for a couple of weeks if you want to check his work out, I went to Kyle after custom cage were unable to produce a cage in time.
Jason
Jason
rosscoe
Aye,I'll have a look down at these guys wen i get back from the orkneys in a couple o weeks,quite local too
cheers
Tam
cheers
Tam
