Fibreglass bonnets ? front bumper lightening!?!
punk_sy
Post Tue Feb 17, 2009 9:06 pm
looking into getting a fibre bonnet just to make the front lighter due to fitting a m50. Who uses these and where could i get one from ? Could it be used on the road with no real problems?
Also heard about cutting some bits out of the front bumper ? any one got any pics or info on this?
gonna go a bit stripped out race style with the IS now :twisted:
cheers simon
handpaper
Post Tue Feb 17, 2009 11:21 pm
Fibreglass bits cheap HERE, see northloop's build thread for bumper lightening.
Post Tue Feb 17, 2009 11:23 pm
nickso
Post Tue Feb 17, 2009 11:47 pm
handpaper wrote:Fibreglass bits cheap HERE, see northloop's build thread for bumper lightening.
handpaper, have you used his stuff?
ive just ordered a sunroof panel from him(you brought it up in my sunroof thread a few weeks back). want to see what the quality is like before i maybe order front wings and bonnet.
'88 e30 328i M52 track bint.
TRACKM3
Post Wed Feb 18, 2009 8:35 am
Give M3BOB a call as he has all the E30 panel moulds, mainly m3 but a lot will fit the std car. i have his number if you want to call him ?
kimbo
Post Wed Feb 18, 2009 12:54 pm
try this
http://www.xlraceparts.com/lightweight-panels-413-c.asp
The all white 325 with split rims modelling a couple of the parts is our car.
The bonnet and boot panels are pretty light, but not at all rigid, so have to be fitted with pins or other q/d fixings.
Kim
initial_g
E30 Zone Moderator
E30 Zone Moderator
Post Wed Feb 18, 2009 10:08 pm
im making a fibreglass bonnet for mine in summer its unbelievable how much wieght it saves,
kimbo
Post Thu Feb 19, 2009 6:13 pm
Most of the weight loss is from the hinges, catches, etc.
In our case the actual bonnet panel is only a little bit lighter than a stripped metal one (estimate around 1.5kg). Thats with all the strengthening ribs, etc removed leaving just the outer skin.
The bonnet hinge on its own is about 2 - 3 kg IIRC!!
Kim
punk_sy
Post Thu Feb 19, 2009 7:18 pm
cheers guys for all the info ill get rid of the hinges and strip one off the 3 bonnets i have for the time being :)
TRACKM3
Post Fri Feb 20, 2009 8:53 am
From Memory std bonnet alone is 21kg and the ones i used to make where 5kg ? you would struggle to get a steel skin that light ?
