Battery cut off switches??
rix313
Post Mon Feb 16, 2009 10:30 pm
Im not sure what to get. Thre's straight forward switches then fancy ones with diode packs.
I had a rumage at dad's work and found some straight forward cut out ones will I be able to fit these to my car?
Rich
shorty73
Post Tue Feb 17, 2009 9:10 pm
Pays your money and takes your choice. Mines a bog standard kill switch which is enough for "scrote-an-earing". No fancy diode just a resistor to dump the load in.
Are you keeping the key ignition or just a switch/button affair?
See us in www.racingsaloons.co.uk helped by,
alloyproducts for alloy fabrications
www.motorsportoils.co.uk for Lucas oil
www.zeroexhausts.co.uk for the noise
MTech 07831831846 for an engine!
drjim
Post Tue Feb 17, 2009 9:34 pm
Cheap ones are OK as long as you wire the alternator positive output wire to the battery positive, not the switched side.
rix313
Post Fri Feb 20, 2009 7:50 pm
This is wat I need help with regarding the whole alternator bypass etc.
I'm going to be keeping the key for now for security purposes though I don't for one second doubt its a piece of piss to hot wire.
oze30
Post Thu Mar 12, 2009 9:16 pm
rix313 wrote:This is wat I need help with regarding the whole alternator bypass etc.
I'm going to be keeping the key for now for security purposes though I don't for one second doubt its a piece of pee pee to hot wire.
Is it the one with the red key? If so, look at how they work, and you'll see that they're not that difficult to bypass! Used to do it all the time in my Jeep, some fecker kept stealing the red key!
rix313
Post Thu Mar 12, 2009 11:03 pm
I meant the ignition key, not just going to have the red key and a button thas what i was saying :)
moggy
Post Fri Mar 13, 2009 1:20 pm
put a switch on the fuel pump
rix313
Post Fri Mar 13, 2009 6:23 pm
The engine will still run for a short time until it starves, the battery cut out is designed to kill the engine then and there and stop anything from sparking a fire.
rix313
Post Thu Apr 02, 2009 6:12 pm
shorty73 wrote:Pays your money and takes your choice. Mines a bog standard kill switch which is enough for "scrote-an-earing". No fancy diode just a resistor to dump the load in.
Do you have a drawing or picture or something of how its wired up? What resistor did you use?
UweM3
Post Thu Apr 02, 2009 8:20 pm
something I am interested as well. Always thought that these switches just disconnect the battery. You live and learn!
SteMarsden
Post Thu Apr 02, 2009 9:15 pm
I'll try and dig out the wiring diagram but essentially:
1. Main contact switches the main battery supply cable
2. Aux 1 switches the coil +ve contact
3. Aux 2 grounds the main feed to 'ground' via a resistor.
I'm sure someone will argue this if its not correct :cry:
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
