Engine choice
LondonTom
Post Sun Feb 01, 2009 10:25 pm
I've been on the look out for a track car recently and have potentially found one, although it running a 3.5 (m30 - I think?).
Does anyone use this motor in their car for track days and if so, what's it like? I was thinking it might be a bit on the heavy side and cause a fair bit of understeer.
If the current engine isn't going to be suitable, what other motors are worth considering? Budget wise I'd ideally want to do it for under £1000 and could do the work of installing it myself.
Cheers guys
Tom
AlpineAde
Post Wed Feb 04, 2009 9:59 am
Yes, it will result in a heavier front end but if it is for a car that is only going to see the track and the track only you can play around with the weight.Think about losing the bonnet and replacing with a CF or GF one; fiddle with the heavy front bumper...strip it, drill it, whatever; lose the sound deadening from the front of the car; if it has air-con" lose it; lose the heater; front guards...GF reps? There are a lot of ways to fiddle with weight distribution. The engine makes good power and has good torque ~ in a lightened car it should do well.
juniorGT
Post Thu Feb 05, 2009 12:55 pm
if youv got a big heavy 6 up front you will want to run a much stiffer spring rates. to cope with the extra weight. you'l find the car will understeer more. but with some fettling you could dial that out. then set about sorting the balance out - battery to the back etc etc
personally i would'nt go 6pot... to heavy - old fashion engine -juicy on petrol.. would rather stick to my little "is" just as much fun cheaper to run and would rain on a 6pots perade!
318is.
Post Thu Feb 05, 2009 3:58 pm
juniorGT wrote:...would rather stick to my little "is" just as much fun cheaper to run and would rain on a 6pots perade!
I kind of doubt that.
JungleGus
Post Thu Feb 05, 2009 4:11 pm
i reckon an m50 - a better m50, m30 is kinda heavy and not great as a track engine. m42 is too gutless (or expensive to make go anywhere). m20 is good a reliable, but not sure how much power you want. a stock 2.5 is plenty fun, not the fastest though. good to learn with
Theo
Post Thu Feb 05, 2009 4:14 pm
For £1000 there's no stand-out option. I would opt for a standard 325i engine as well, as there's none of the messing around associated with a non-standard engine swap.
juniorGT
Post Thu Feb 05, 2009 5:16 pm
lol haha... im not going to even bother with the 6pot v 4pot malarky !
doubt away my friend doubt away. :D :D :D
318is.
GrindCulture
Post Thu Feb 05, 2009 5:21 pm
For a cheap, fun track car I'd opt for a 325i all day.
Not in E30s any more :(
JimmyC
Post Thu Feb 05, 2009 5:27 pm
get a 320 or 318 then you can progress to http://www.pbmwc.co.uk
Post Thu Feb 05, 2009 5:33 pm
When you refer to 6 pot, is that a generalisation?
GrindCulture
Post Thu Feb 05, 2009 5:36 pm
I smell your S50s first victim :twisted:
Jon_Bmw
Dangerous when thinking
Post Thu Feb 05, 2009 6:00 pm
No thats me in a couple of weeks time! :(
Post Thu Feb 05, 2009 6:05 pm
Jon_Bmw wrote:No thats me in a couple of weeks time! :(
I fear my talent will prevent that!
LondonTom
Post Fri Feb 06, 2009 9:49 pm
Cheers for the info chaps - work isnt a problem, so would consider an engine swap. Have been on the look out for an s14 recently.
