e30 m3 track day car rebuild pics
zerocool
Post Sat Jan 03, 2009 7:05 pm
picked up this a month ago,it will be my dedicated track car, its a little ripe,so out comes the grinder
/CIMG1610.jpg[/IMG]
paddyvw
Post Sat Jan 03, 2009 8:20 pm
nice evo two. pity to see it getso bad by previous owners. what are plans for suspension and power? youleaving the billies and h and r set up or coliovers?
UweM3
Post Sat Jan 03, 2009 8:38 pm
nice one! So what are your plans? Cage? stripped? :D
Francisco
Post Sat Jan 03, 2009 8:48 pm
Want to sell her?
fuzzy
He who sleeps with "Gingers"
Post Sat Jan 03, 2009 8:59 pm
i want to tackle bodywork repairs but im still waiting for the rust to start on my touring. i cant imagine id let it get in that state though. the previous owners didnt look after that very well.
zerocool
Post Sun Jan 04, 2009 9:12 am
cage will be on the list but not for a while,48mm throttle bodies next,already has bigger headers,and ported head
stripping out interior,and will be removing sunroof cassette too
got a track day on the 13th of feb,so I just need to get the bodywork side done first
UweM3
Post Sun Jan 04, 2009 11:53 am
if that's an EVO2 you won't need 48mm throttles to make more power. EVO is the only M3 engine which makes the power BMW claims IMHO. All others (including the mighty Sport EVO) are down on factory power.
EVO2 throttles are the most difficult bit to source! Don't give them away. Difference is the casting towards the head which is larger than the "standard" 46mm throttle bodies. Evo2 inlet ports are same size as 215bhp engine, hence the larger throttle casting.
I would put the cage on the list of modifications BEFORE the engine. It will transform the handling of the car if done right and will make you faster on track even without fiddling with the engine.
If the engine is healty (or near) I would NOT touch it till a full rebuild is on the cards. (start saving, it will cost a bomb)
My list would look like this:
take care of rust
weld in cage (which may well go hand in hand with rust repairs)
fit buckets and 6 point harness (if you have a cage)
STRIP interior and whatever you don't need/want (removing weight is the cheapest power upgrade)
sort out suspension (Bilsteins and H&R race springs, or do a DIY coil over conversion for decent track handling)
sort out brakes (300x32mm Merc disks front with E34/E32 calipers)
and then drive the car for a season.
you may well start off with a "milder" suspension setup for a year (Billies and H&R) and then move on to the more hard core stuff (which is unsuitable for the road, full stop), give yourself time to grow WITH the car. Don't build an all out track monster with all the bells and whistles and you don't like it afterwards.
The suspension I am driving now would have not been suitable for me 3 years back, I just wasn't fast enough for it.
It doesn't make much of a difference on track if you have 220 or 250 bhp but it will make a huge difference on your credit card. I would spend the money on handling and braking, that's where the fun comes from (and the lap times.....)
Post Sun Jan 04, 2009 1:00 pm
UweM3 wrote:It doesn't make much of a difference on track if you have 220 or 250 bhp but it will make a huge difference on your credit card. I would spend the money on handling and braking, that's where the fun comes from (and the lap times.....)
He talks sense!! :D
zerocool
Post Sun Jan 04, 2009 1:28 pm
thanks for the advice,the car is not an evo2 unfortunatly,just has the coloured rocker and airbox
already has H and R springs and billys on it,but I have a ground control kit sitting in a box that I bought for my other e30 m3 (schnitzer s3)
not sure the cage will go in this year due to funds,but it will be stripped out to reduce weight,its already poly bushed and has braided hoses,big brake upgrade sounds interesting though
