Roll cages
Rik178m
Post Tue Oct 21, 2008 12:25 pm
Hope this hasn't been asked a thousand times before!
What Diameter, gauge and type of steel are roll cages made from? I am confident I could make 1 that isn't going to cause more harm then good so might go DIY.
Daf318is
Post Tue Oct 21, 2008 12:27 pm
Couple of cars i've had them in the past have all been 50mm.
I think if you check customcages website they say what diameter and gauge they use for all the different bits of cage.
Daf
stof
Post Tue Oct 21, 2008 1:09 pm
dont know if this is any good to you?
http://www.merlinmotorsport.co.uk/SHEET ... 37398e5039
juniorGT
Post Tue Oct 21, 2008 10:02 pm
custom cages are brilliant for setting the basic "frame" (club kits CL2 rear cage design) they do need a bit of jigging, but they are cheap and can supply extra CDS, you can add to it, or you can just go for the multipoint jobby which iv heard is a bit of a nightmare to fit, but once is is excellent ! or there is safety devices which are brilliant bolt in kits lovely qaulity and fit a treat no welding needed
