skyline brakes
rickyc
Post Fri Oct 03, 2008 5:12 pm
I'm thinking of upgrading the brakes on my 320, anyone know if r33 skyline gts-t brakes will fit? I think it's doable?
BadDave
Post Fri Oct 03, 2008 8:08 pm
I can't find the specs for the disks unfortunetly
I can only find the specs for the 2.6GTR from january 97 and they have a 59mm offset
You'd need a 20mm spacer between the hub and disk to let them clear the track rod end
If you can get me the distance from the inside face of the disk to where it contacts the wheel hub, i'll be in a better position to advise
HTH
Black_Potato
Post Sat Oct 04, 2008 6:45 pm
Simply from a performance pespective there is nothing wrong with the standard ones if you run decent fluid, braded lines and good pads. i.e. PAGID RS29 or similar.
rickyc
Post Sun Oct 05, 2008 3:45 pm
I've got drums on at the moment, so not great lol.
Unfortunately the skyline brakes I could have got might have already gone. But I'll try and find out the spec.
What would be a nice alternative upgrade?
GrindCulture
Post Sun Oct 05, 2008 3:48 pm
Black_Potato wrote:Simply from a performance pespective there is nothing wrong with the standard ones if you run decent fluid, braded lines and good pads. i.e. PAGID RS29 or similar.
Not in E30s any more :(
Post Sun Oct 05, 2008 5:36 pm
I'd be more worried about getting a 320i to go than to stop...
Rear discs are your 1st port of call
fuzzy
He who sleeps with "Gingers"
Post Sun Oct 05, 2008 5:42 pm
change your rear axle for a disc set up from a touring or 325 etc then fit uprated parts.
rickyc
Post Sun Oct 05, 2008 11:44 pm
have a 325 engine in so not too bad for power
new axle and other parts is the way forward then
thanks
Karan
Post Wed Oct 15, 2008 8:55 pm
ive tried this it wont work......
shorty73
Post Wed Oct 15, 2008 9:15 pm
Just get yourself a wilwood kit from rally design or somewhere. No messing!
See us in www.racingsaloons.co.uk helped by,
alloyproducts for alloy fabrications
www.motorsportoils.co.uk for Lucas oil
www.zeroexhausts.co.uk for the noise
MTech 07831831846 for an engine!
BadDave
Post Thu Oct 16, 2008 4:17 pm
Heres a possible cheap big brake kit that could be made to fit
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0298443834
