Total removal of the original fuel system - pump, tank, filler, fuel lines, fpr, injector rail and injectors.
Fitting of either one 100 litre LPG tank on the rear seat pan or several smaller tanks in place of the petrol tank. I've seen 10" given as a minimum ground clearance for an underslung tank, so I may have to put up with 60-odd kilos fairly high up in the car.
Swirl pot, almost certainly in the engine bay as it's the only legal place for it. Calculations based on fuel consumption at the 'Ring give a figure of 15 ml/second at full chat, so it would have to be at least 300 ml to provide a decent safety margin.
I'm not sure how an LPG swirl pot would work - since there's no fuel pump or return line in the system how would it get rid of gas fed in when the liquid was away from the dip tube?
Would it just recondense under pressure?
Replace the AFM with a bit of pipe. I'm hoping the Motronic ECU doesn't vary ignition timing (much) with load, otherwise something must be devised to fool it. I already have a throttle body-mounted mixer venturi fitted.
Advance the ignition timing, either by moving the crank position sensor or re-keying the bottom pulley wheel. It may be necessary to slot the bolt holes in the distributor cap and turn it slightly, or re-key the rotor arm for this to work.
Increase compression by whatever means is least complicated. Machining the block is simplest on the face of it, but may cause valve-to-piston contact.
By my calculations, to achieve a CR of 12:1 I must reduce the combustion chamber volume from 53.3 cm^3 to 37.8 cm^3.
This equates to skimming 2.8mm from the block. How feasible this is I don't know.
The only thing listed here that I can't do myself is the compression increase, annoying since it's the one most likely to give a decent power gain (10% according to theory).
More may come from fitting a six-branch exhaust manifold and, if possible, a hotter cam.
Hopefully I'll have something worth playing with in a month or so
Comments and suggestions welcome
