M3 top mounts ?
paulg390
Post Wed May 14, 2008 10:23 pm
Heard a rumour that standard M3 top mounts bolt straight on to non M3 E30s and give a couple of degs neg camber ?
Anyone know if this is True or False ?
White 318iS, 2.7 conversion, LSD, H&R cup kit, ARBs, F&R strut braces, full cage, kevlar buckets, wilwood 4 pot brakes, braided hoses, 6pt harnesses, f/glass bonnet, Toyo 888's, scorpion, polybushed, carbon cards and boot lid.
UweM3
Post Fri May 16, 2008 1:30 pm
False, all E30 top mounts are the same.
Dan318-is
Post Fri May 16, 2008 2:19 pm
But you can buy fixed camber top mounts from bmw.
Or you could get some of uwe :)
paulg390
Post Fri May 16, 2008 2:42 pm
Cheers, thought as much :? but thought I'd just check...
