Stack ST200 rpm guage
Mox3d
Post Sat May 03, 2008 7:24 pm
This is to see if there's any point me either hanging on to mine or selling. As the header says I have a Stack ST200 guage calibrated up to 8k rpm. It has a shift light, max rpm telltale and lap memory functions.
It is complete with the one exeption of missing the connector which wraps around the coil lead only. The entire loom is otherwise as it should be. If it helps I could probably buy in the missing connector or whatever, not a major problem. The unit is otherwise as new.
They retail from Demon Tweaks at around £189 pounds or just over with the shift light costing an extra £26 pounds.
The unit is shown on the page here -
http://www.demon-tweeks.co.uk/products/ ... T200-04105
It is a motorsport item only for racing use. What would mine be worth to you ?
blitz877
AKA ajm-e30
Post Sat May 03, 2008 7:43 pm
i been looking for one of these for a while, how much you after for it?
Mox3d
Post Sat May 03, 2008 7:59 pm
Make me an offer I can't refuse and it's yours.
Mox3d
Post Sat May 03, 2008 8:26 pm
For what its worth I've taken a couple of shots. The unit is sitting in the box mount as was used in my M5 (see sig). If I sell I'll let it go as is with the mount to help with button and shift light wiring. Also I have a pdf of the ST200 manual.
As I mentioned, the only thing I'm going to try and do is buy a new sensor/pulse lead to complete the unit. The black wire and thicker orange wire were cut upon removal as shown in the images. It is these that will want replacing and/or fresh connectors.
