As the pipe turns forward towards the pump the angle is too acute and has clearance issues with the bulge in the side of the sump pan so has to be straightened out to run just in front of the engine mount.
The other smaller pipe is from an old pre-facelift steel rack from the E30 that needs to be straightened slightly around the pinion housing and then shortened and the banjo re-braised back onto the end (£10) which was a cheaper option than finding someone to make new pipes.
The 13mm spacers i had made (£15) and are placed under the rack because of the ground clearance issue with the pinion housing.
Not bad for a total cost of £115.
