track day fun is not going to happen for a while, isn't itJhonno wrote:
I need to stop spending on building and start actually spending on track days at some point!!
watch this space......
the new surface suited the skyline owners with their 4wd and electronic cheats well... i was struggling for rear traction in 3rd. it seemed to take an age to dry out too. if you go wide turning into clark curve, it's pretty tricky getting back on line.RPM wrote:How was the new surface Gareth?
Heard its a bit sketchy in the wet at the mo?
Playing there this friday
Haha...i like that!!gareth wrote:that's me!that corner where the seven cought me up was a bit sketchy, the car in front was pulling off but understeered straight across the track in front of me as he was on a wet line to turn into the pits! Missed that in the video though.
the other white E30 is danny_duke01 on here, driving mostly sideways
I completely agree with you there Gareth...it did seem to take ages for the track to dry out and yes if you did go off line it was very slippery getting back on line...(not that i noticed too much,as spent most of the day going sideways!!)gareth wrote:the new surface suited the skyline owners with their 4wd and electronic cheats well... i was struggling for rear traction in 3rd. it seemed to take an age to dry out too. if you go wide turning into clark curve, it's pretty tricky getting back on line.RPM wrote:How was the new surface Gareth?
slipppppery!![]()
Try some Hankook RS2's..DanThe wrote:Hottest I got today at Oulton was 56, on the outside of the front leftInsides were only about 2 degrees out so camber was good. Proxies however are shite when you have reasonable suspension and power
It was very annoying being limited by the screeching of tyres, up to 5 or 6 laps they were ok but once hot they seemed to turn to jelly
When I had the MR2 all 4 had worse beading than that (although it was pretty even across the entire width of the tire) after about 6-8 laps. I couldn't say that they were going off, I was acutally going faster, almost as if they were at prime temperature as it took another 15-20 mins before they got "greasy" and the car started feeling loose (no temps available). But having said that, as much as I hate to bow down to jap crap, a mk2 MR2 is an awesome chassis, so readable and predictable it makes an e30 feel like a Rowntree's jelly in comparison......so much so I was keeping up with an M6 driven by a pussy around croft with a shagged 150K miles 2.0 litre 1300kg MR2 with some cheap lowering springs and a set of proxesDanThe wrote:Hottest I got today at Oulton was 56, on the outside of the front leftInsides were only about 2 degrees out so camber was good. Proxies however are shite when you have reasonable suspension and power
IMO best way to go mate.DanThe wrote:Send me some prices via pm then![]()
Been offered some 888's today so may be going that way....
can you get a good deal on 888's Dez?Dezzy wrote:IMO best way to go mate.DanThe wrote:Send me some prices via pm then![]()
Nobody has a bad word to say about them.
I haveDezzy wrote:IMO best way to go mate.DanThe wrote:Send me some prices via pm then![]()
i had a measure of tread depths earlier (i noted them before the track day) and have go the following wear:DanThe wrote:How did you find the tyres held up with your suspension?
