The inspection of the steering lock only applies to passenger cars with:
a steering lock fitted as standard by the manufacturer, and
four or more wheels, and
not more than 8 passenger seats excluding the drivers seat, and
first used on or after 1 September 2001 The check does not apply to quadricycles.
If there is doubt as to whether a steering lock was originally fitted, the benefit of the doubt should be given.
It is acceptable for a steering lock to be removed if it has been replaced with another immobilisation device (Key in barrel retention, EWS and obviously removable master switch toggle feature here).
But then, under reasons for failure:
4. a. A steering lock mechanism inadvertently engaging
b. a steering lock mechanism missing or fails to engage
c. an electronic steering lock system malfunction warning displayed.
Information taken from here:
http://www.ukmot.com/manual/2.1/Steering-Control
Thanks guys.
