Increasing front end grip.
Hey guys,
I have been struggling to maintain front end grip in long sweepers and also in variable radius bends where they start smooth and tighten up before the exit.
The main problem seems to be understeer where I can't get the power down without drifting off course. I have tried playing with f/r tyre pressures, taking different lines and also slower entries but I am still losing time in these segments due to a lack of front end grip.
Any ideas?
Any ideas?
-2 degree toe in on the front, standard camber except for the eccentric control arm bushings.
Rears are totally standard with E46 top mounts.
Bilstien B6 all round with Stiffer springs.
Standard 318is ARB set up and braking system.
All of the bushes and bearings are new original BMW items
- randomspeedfreak
try unbolting front arb? do you know your spring rates ?
Not sure about spring rates. They are gmax 30mm lowering springs. I will unbolt the front arb. Thinking about it there is probably 30mm of pre-load on there trying to push my inside wheel down when cornering.
I will also toe out the fronts. How much toe out would be recommended?
- Superleggera
You need some 'toe out' and you could also try increasing your castor as this will aid your dynamic camber.
Do you know where I can get shorter drop links? The arb appears to be loaded up due to lowering the car and it does not sit parallel. It looks like it is pushing down on the control arm and my mondeo drop links dont have much slack left for free movement. ( it is at an angle and the rubber boot is fully compressed on one side of the droplink)
OK, small update, I checked my tracking today using the string method and I am 0 degrees at the front pointing straight ahead. The rears are about 3mm toe in, is this normal?
I have sorted the pre-load on the ARB. Just loosened the bushes, oiled and tightened the bars are nor sitting parallel again. Still understeering though.
When I get time I will try toeing the fonts out a bit and see how that goes.
The rears are not adjustable but are they meant to be toe in?
