I'm putting together a gaz coilover set up for my drift car,
Im going to be runing Gaz/Leda true coilovers on the rear and E36 m3 gaz golds on the front(as Im also converting to 5 stud)
I know there's a science behind spring rates etc, I have some ball park starter rates in mind but would like a bit of input on what the normal spring length would be?
gaz Coilover spring length
Im running 210mm rears (not Gaz or Leda) but that should give you a figure to run with.
Thanks for that
