Lightweight motorsport battery
DasChin
Mon May 07, 2012 8:48 am
anyone using a non standard big battery in your e30?
any options/costs?
my car has the normal big battery and boot mounted.
want to go smaller but not sth that won't crank the 6 cylinder.
thanks. DC
Demlotcrew
Mon May 07, 2012 11:18 am
To get the smallest battery possible ive had to also invest in a Brise starter http://www.brise.co.uk/BMW_starter_motors.html
When commuting in the car to track i use the stock battery, once on the track I fit the little one. Eventually i would like to fit the racing one behind the passenger seat (when that gets fitted) and keep the cable going to the back so i can simply remove the OE once at track and not mess about fitting or connecting the racing one.
These are also not bad value, but they are not as light.
http://www.ebay.co.uk/itm/Nissan-MICRA- ... 722wt_1211
Andrew
milescook
Mon May 07, 2012 12:25 pm
http://racing.cookieonline.net/e30-320- ... b-rollcage
I was recommended an Odyssey battery haven't raced it yet! Starts the car fine.
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
pdd144c
Mon May 07, 2012 4:21 pm
Got an Odyssey Extreme 30 in mine, 9kg and never had any issues with starting etc... It's located behind where the passenger seat would normally be. Best to keep it between the two axles if you can.
TRACKM3
Mon May 07, 2012 10:10 pm
Used a 25 for years in my E36 Nick no problems at all.
DasChin
Tue May 08, 2012 10:52 am
thanks all.
racing one it is then behind passenger seat.
current battery is 17.5 kgs so needs changing. i reckon there is 11-12kgs take out there!
Hoobs
Wed May 09, 2012 4:50 pm
I bought a second hand red top race battery off Pistonheads for £50 and it weighs a little over 5.5kgs, compared to the 16kgs of the OE item. It cranks the OE starter with no problem and only mod I made was changing battery terminals.
http://www.varleyredtop.com/products_batteries.htm
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
rix313
Wed May 09, 2012 10:43 pm
My Odyssey 25 battery was £50 2nd hand. Check out the rally design ones. They're made by DMS technologies, just branded differently and cheaper!
HairyScreech
Tue May 15, 2012 12:33 am
roadrally_nova
Thu Aug 30, 2012 1:15 pm
for dry cell batterys give these guys a bell brand new £44. had one in our car for 3 years no problems
S&R auto electrics
llandudno junction
n/wales
01495583444
