hi there
im amazed with my cars new handling i recently fitted a e36 rack and adjustable top mounts. what a difference the rack makes specially for doing a bit of drifting it so much faster. i dont know wheather im correct but i can go alot faster into corners with the adjustable top mounts i have them set at -1.5 degrees is that ok for road use. if i set them to -3 degrees would it make much differnce to tyre wear and handling?
thanks in advance nicky
what a difference
- Mikey_Boy
Hi Nicky - I am currently running GAZ coilovers with adjustable top mounts with 2.5 degrees neggy at the front and 8 degrees castor. I am also running a Z3 rack.. No issues with tyre wear so far (R888's) but the only thing I find is that the car tends to tramline a bit on the road, but that's a small price to pay for the better turn in on the track and for drifting. Standard set up I think allows up to nearly 2 degrees camber and 9ish degrees castor? I haven't tried any more camber yet. Worthwhile to follow some set up principles depending on primary use (road or track) but of course you should go with what feels best for you!
Cheers,
Mikey_Boy
Cheers,
Mikey_Boy
steve_k
- Contact:
hope you don't mind me asking dude but what spring rates are you running on the front coilovers? (ilbs/inches?)Mikey_Boy wrote:Hi Nicky - I am currently running GAZ coilovers with adjustable top mounts with 2.5 degrees neggy at the front and 8 degrees castor. I am also running a Z3 rack.. No issues with tyre wear so far (R888's) but the only thing I find is that the car tends to tramline a bit on the road, but that's a small price to pay for the better turn in on the track and for drifting. Standard set up I think allows up to nearly 2 degrees camber and 9ish degrees castor? I haven't tried any more camber yet. Worthwhile to follow some set up principles depending on primary use (road or track) but of course you should go with what feels best for you!
Cheers,
Mikey_Boy
- Mikey_Boy
Hi Steve - honestly, I have no idea! I asked the guys at RPM for their best judgement for my car - it's a trackday car that's driven to and from the track - they took it from there and I have to say, it's been very good so far!
And before anyone suspects - I have nothing to do with Gaz!! Would suggest you get in touch with them - very helpful bunch!
steve_k
- Contact:
no worries fella look's like i've got it sorted nowMikey_Boy wrote:Hi Steve - honestly, I have no idea! I asked the guys at RPM for their best judgement for my car - it's a trackday car that's driven to and from the track - they took it from there and I have to say, it's been very good so far!
