GAZ Gold Coilover Suspension E30zone Deal
JimmyC
Wed Oct 01, 2008 4:34 pm
After significant interest for a performance coilover solution on here, I have approached GAZ Shocks http://www.gazshocks.co.uk to offer a discounted price on their products to the club.
I'm also pleased to announce that they will be the title sponsor next year for the Production BMW Cup http://www.pbmwc.co.uk, where a large number of the filed run these coilovers.
THE SHOCKS
The deal is for a full set of GAZ GOLD coilover shocks, front and rear including springs and rear rose jointed top mounts. These are fully hieght adjustable and one way damping adjustable, changing the bounce and rebound on the damper. You can specify you own spring rates when you order, and GAZ will be able to advise you based on the large amount they sell for the e30 cars from 318's to M3's.
I run these on my car and cant say a bad word about them, a sentiment shared by over half of the PBMW field and the series leading M3 of John Wilcocks in TTRS.
THE DEAL
The cost for the above (please not adjuatable front top mounts avaliable at extra cost) is £675 + VAT + Delivery and is based on an exchange basis of your front struts
THE EXCHANGE
The front coilovers are based on the standard front hubs, as such the sale is based on an exchange basis. GAZ have built units on the shelf so you wont be without your struts for long. In reciept of your struts and payment your new coilovers will be sent out. Old struts should be stripped down, anything left attached will not be returned.
CONTACT
Either speak to Dave Lyons or Warren Gazzard or Mark Gazzard, and mention its the e30zone deal
e: enquiries@gazshocks.com
t: +44 (0)1268 724585
f: +44 (0)1268 724536
Gaz Shocks Ltd
Rayridge House
Swinborne Road
Burnt Mills Industrial Estate
Basildon
Essex
SS13 1EH
Wed Oct 01, 2008 6:04 pm
BadDave
Wed Oct 01, 2008 6:20 pm
Is there a deal on the rears seperately
Only ask, as i already have the fronts
james3320
Wed Oct 01, 2008 6:23 pm
BadDave wrote:Is there a deal on the rears seperately
ive already got rears mate, so if they dont sell them seperatly maybe we
could split a set, 8)
cragles
Jimmy, it's Craig, Neil (neilbtcc's) brother. Just to add a couple of bits, I think that GAZ will accept 45mm or 51mm struts since they only use the bottom part... and the bottom of the rear struts is now offset, i think this is so that the rear coilovers clear the fuel pipes etc in the right rear arch. :D
JimmyC
Wed Oct 01, 2008 7:23 pm
Sure they will split, they priced the PBMW deal as individual elements so sure its not a problem
Call them and ask :)
Cheers for the info Craig
BadDave
Wed Oct 01, 2008 7:35 pm
JimmyC wrote:Sure they will split, they priced the PBMW deal as individual elements so sure its not a problem
Will give them a call either tomorrow or Friday then
Theo
Wed Oct 01, 2008 7:49 pm
Well done for sorting this out Jimmy, very kind of you.
I will be taking advantage of the offer very soon.
Andyboy
Alpina Colada
Wed Oct 01, 2008 7:59 pm
Nice work - Gaz stuff is very good and comparable to Leda.
winx
Thu Oct 02, 2008 12:09 pm
What are people's honest thoughts on running these in a roadcar. The one I am building will start as a 90% roadcar and slowly evolve to a track day toy over a few years.
I want to have decent ride comfort, will this be acheivable with the right springs?
Also on a touring, what do I need to do to the rear shock towers for reinforcement?
e21Jason
Thu Oct 02, 2008 12:59 pm
I just got a set of GAZ to replace the LEDA's on the e21, better than the LEDA as front are larger strut housings, more adjustabilty and a better finnish.
Nearly temped for a e30 set for future use.
Jason
handpaper
Thu Oct 02, 2008 1:11 pm
Pick the right spring rates and you'll be fine, though you may have to use spring compressors to fit them.
There's a list of spring rates HERE, closest to OE would be 14", 120 lb/in front and 16", 100 lb/in rear* but you can choose whatever suits you best from Faulkners as they supply Gaz.
*Yes, that rear spring rate is correct. This is a full coilover conversion, where the rear suspension acts on the trailing arm shock mount, not the OE spring perch. As such, it has more leverage over the wheel and doesn't need such a high spring rate. To convert other (OE perch) spring rates, divide by 2.77.
This is the square of the ratio of the distances from the pivot axis of the different spring mount points.
winx
Thu Oct 02, 2008 1:30 pm
Handpaper thank you for the reply, very informative! I will look a bit harder into this, just about to buy some wms brakes and these then should be done for a bit spending on this project!
Chase007
Thu Oct 02, 2008 1:37 pm
Very nice! 8)
Reeeedish
Sun Oct 12, 2008 10:27 am
I use these on my E30 - they are a fantastic kit for the price!
I have plenty of sets of E30 front struts in stock if anyone needs them to buy for the exchange to Gaz. I offered this last time round and a few people purchased them. I can send straight to Dave @ Gaz for next day delivery with all your details on.
Currently 4x sets of larger 51mm struts in stock.
These will come already stripped down so Gaz or you have no work to do.
£58.75 including vat, and next day P&P for a 51mm set
You can contact me here, via PM or email/phone via details on the website http://www.Beemer-Redeemer.com
James :D
Andye
Wed Oct 15, 2008 7:34 pm
Has anyone got a set of M3 fronts for sale that I can use for this deal?
JimmyC
Wed Oct 15, 2008 10:37 pm
Call Richard from BBB, number below :)
Andye
Sun Oct 19, 2008 8:54 pm
Reeeedish
Mon Oct 20, 2008 5:15 pm
FAO Gavin Halls,
Your 51mm struts went out to Dave Lyons @ Gaz today and will be with him in the morning. I've informed him that they are on their way.
3 sets of 51mm's left in stock for anyone else who's interested.
James
Soundstorm
Tue Oct 21, 2008 4:16 pm
How wide are the rear coilovers? Is the shock about the same size as the standard non-coilover or is coil + shock about the same size?
It's probably a bit wider, so that would limit the size of wheels used. Or am I thinking too extreme and will wheels hit something else first? :mad:
flyingfarrier
Thu Oct 23, 2008 7:53 am
Thanks James you have been a great help, will post some pics of the car when its finished, :D
JimmyC
Thu Oct 23, 2008 10:09 am
Soundstorm wrote:How wide are the rear coilovers? Is the shock about the same size as the standard non-coilover or is coil + shock about the same size?
They clear a 195/50/15 on a 7J wheel fine
What wheels are you looking to run?
If you call Gaz they can give you exact diameters
Soundstorm
Thu Oct 23, 2008 11:38 am
JimmyC wrote:They clear a 195/50/15 on a 7J wheel fine
Nothing is decided yet. It's a project car and I'm just making up the shopping list :wink:
But the rears will probably be 9 or 10 wide. There are 9's on it at the moment with KW shocks, but I can't realy remember how much clearance there is.
But I was thinking about these shocks the other day and a new 'problem' came up my mind. In my opinion a coilover is superior to a shock + coil. But doesn't that mean that all the weight of the car will be on the shocktowers if you take coilovers?
If you use shock + coil, the weight is on the frame (2 square bars if I remember correctly, so quite strong) and only the shocks are thransfered to the shocktowers.
Does that mean that you have to re-enforce the towers to use coilovers? I was planning to do that anyway, just to be on the safe side. But coilovers would mean I HAVE to do it.
JimmyC
Thu Oct 23, 2008 11:56 am
Should be fine with the towers as they are, most of the PBMW cars running them dont have reinforced towers, others have th cage tying in but not anything on the top
Haven't seen one fail, and thats with lots of curb running ;)
Soundstorm
Thu Oct 23, 2008 5:42 pm
Ok, thanks!
Would be sad to se the towers ripped apart after a bumpy ride when you've put all that hard work in the car.
cragles
Thu Oct 23, 2008 11:18 pm
You can always reinforce the rear top mounts as a precautionary measure with some z3 reinforced top mount plates - thats what we have done.
Bruce does them in the "group discounts" area on here.
BadDave
Mon Nov 03, 2008 10:00 pm
Phoned Dave today for a pair of rears
He was helpfull as always
There just waitng for a batch of rear topmounts to come in(despatched today apparently) and my rears should be sent out by the end of the week :thumb:
Thanks for sorting this one out Jimmy
