Brakes
Motox_engineer
Wed May 28, 2008 7:16 pm
i have a Tech 1 and the brakes are rubbish... my brother's mk3 polo has a better pedal. ive bled loads of fluid through the system but nothing..
this is my second tech 1 and they both are the same are they just like that?
also what is good caliper & disc upgrade that cost under £350 and fits in the original 15's
cheers
agent006
Wed May 28, 2008 7:31 pm
Braided hoses will help a soft pedal.
UweM3
Wed May 28, 2008 8:35 pm
I think if you fit braided hoses you should also consider to fit a new Master cylinder and caliper rebuild kits
Our cars are quite old now and all brake related parts will suffer over the years.
shorty73
Wed May 28, 2008 11:19 pm
Bigger M/C, braided hoses and possibly copper lines (mine were shagged!) Ebc turbo grooved discs and yellow pads and a good fluid. Stops like a mudda fugga! And forget all the shite about ebc yellow being no good. Work perfectly with right discs.
Worth overhauling the calipers too.
Motox_engineer
Thu May 29, 2008 7:06 pm
And what are the correct disc's?
I may go for red stuff pads...
what braided lines shuld i get, i'm on a bit of a buget..
shorty73
Thu May 29, 2008 7:33 pm
Ebc discs seem to work well. Others may do as well but I've only used the ebc turbo grooved ones.
Goodridge do a hose kit. Reds will Be ok for road/track. Yellow for track/race.
