Next mods ? iS
Done the first track day today at Donnington, hello to the guys with the Red 325i 4 dr and the grey 2dr Sport.
So far have done the following and need suggestions on what next:
New 205/55 15 Dunlop SP's
New grooved discs, sport pads and dot 4 fluid
KW sports suspension
Stripped out interior with 3 point harnesses
Bought but not fitted yet ...Powerflex lower control arm bushes
oil change, panel filter
Lookin forward to your thoughts
march109
- Contact:
When you say its stripped out have you removed everything? Underseal? Sound deadening? Sunroof? ect..
A zone chip will even out the flat spots for little outlay! £60ish
6 branch manifold may release a few ponies £200
big bore throttle body is a proven mod if a little pricey for what it is. (zone shop link EVOLVE above) other shops are available.
H&R roll bars,
I'm not sure about your choice of sspension no experience myself but haven't heard them spoken highly of.
Be easier to suggest options if I knew your budget.
H&R roll bars,
march109
- Contact:
hmm did you sa you have a 6 pot or an iS?
march109
- Contact:
Ok forget the 6 branch then
Or don't and fit a M20b25 engine! you kno you want to!
Or for £500 chip the 318is and get some roll bars. Also loose some more weight, theres alays the items I mentioned above, theres also about a foot and a half too much of dash that an angle grinder will sort, and always spare loom not being used. Theres also stuff in the bumpers.
Theres quite a few threads on the zone motorsport section hich document ingenious ways to get more weight out of your car.
where is the spare loom ?
the KW was within budget and reco'd by Evolve,....felt okay today. any ideas on the price of the H7R roll bars, why are they better than std ? thicker ?
Not sure i am brabe enough to take out the dash yet !
march109
- Contact:
Most E30s were fittd with the full loom which includes plug in points for extra options that ern't necessarily fitted, for example you'll find obc iring in there, possibly wiring for heated windscreen washers ect ect.r4rick wrote:where is the spare loom ?
The H&R roll bars are thicker (stiffer) and adjustable.
- alloyproducts
i know it may be out of your budget but we are developing a throttle body kit using m3 e36 bodies. we have just finished developing a race loom to run the emerald k3 ecu as well. we are currently developing this on a customers car and should have pics and progress reports soon.
Hmmm, interesting...alloyproducts wrote:i know it may be out of your budget but we are developing a throttle body kit using m3 e36 bodies. we have just finished developing a race loom to run the emerald k3 ecu as well. we are currently developing this on a customers car and should have pics and progress reports soon.
Don't have funds for this but it is on my to do list
I was plannng on going this route too, I don't like the Dilabas ITBs since the cost as well as cylinder 1 looks like it could be starved of air...
Front wishbone bushes. Best mod £ for £ I've ever done (apart from change brake fluid!)
Andy
Andy
I'd look towards a roll cage with your setup.
Regular seats and seatbelts are designed to move and allow movement in an accident. If the car rolls there is a safety factor that allows you to bend forward or to one side.
With bucket seats and harnesses you are held upright. If the car rolls and the top of your helmet is higher than the top of the seat you get the full force onto your head, neck and spine.
Even if your helmet is lower, you then rely on the seat to withstand all the force of the roll. If mounted to factory positons rather than welded onto proper fabricated seat mounts, onto welded in plates and using high tensile bolts, the seat mountings can break wrapping the car around you.
Again in a side impact, harnesses won't allow you to move, and a lot of cars go off track sideways. If you brush along a barrier it's fine, but side on into a tyre wall with a seat and harness holding you in place? No thanks!
Worth thinking about at least...
For absolutely no cost. Remove the viscous fan, power steering pump, belt and the pulley. This has the same effect as lightening the flywheel.
Steering is only heavier below about 15 mph without pump.
Stratos.
Stratos.
318 is.
I have an iS with lightened m20 flywheel, quick shift, panel filter, jetex exhaust, evolve chip, and taken the heater plate off and last saturday i took it round curbrough sprint circuit. There is lots of accelerating from low speed corners and trying to get the power (dont laugh) down as quickly as possible. So next thing on my list is an LSD if i can find one, as i was just wheel spinning in 2nd and 3rd (yes it was raining and very greasy).
