hi, can i have prices on the following please?
4x Bolts - 33 32 1 095 102
4x Nuts - 33 32 6 760 668
1 of everything here other than the drive flange (shim prices for reference)
http://www.realoem.com/bmw/showparts.do ... g=33&fg=10
items 2, 3, 5, 7, 8
a bit of a shopping list
gareth
zimmerbimmer1
- BMW Parts Meister
Hi There
1 B33.32.1.095.102 ECCENT-BOLT 4 £14.69
2 B33.32.6.760.668 Nuts 4 £1.19
3 B33.12.1.200.284 PROTEC.-COV 1 £1.13
4 B23.21.1.490.120 Locking Plate 1 £0.73
5 B33.10.1.214.099 OIL SEAL 1 £8.93
6 B33.12.1.203.615 ROLLER BRG. 1 £36.64
7 B33.12.1.203.616 ROLLER BRG. 1 £37.15
8 B33.12.1.744.368 CLAMP BUSH 1 £4.36
9 B33.12.9.065.179 SHIM SET 1 £18.61
10 B33.12.9.065.180 SHIM SET 1 £18.61
11 B33.13.1.208.006 PROTEC.-COV 1 £0.51
12 B33.10.7.505.602 SHAFT SEAL 1 £8.51
13 B33.13.1.213.893 ROLLER BRG. 1 £32.48
14 B33.13.9.065.734 KIT 1 £23.58
15 B33.13.9.065.735 KIT 1 £23.58
gareth
fantastic, cheers
i'll have a close look at the diff bits to see exactly what needs replacing and get back to you with a precise list!
gareth
Hi, can i have current prices and availability for the following bits i need please?
B33.12.1.200.284 PROTEC.-COV x1
B33.10.1.214.099 OIL SEAL x1
B33.12.1.744.368 CLAMP BUSH x1
B33.13.1.208.006 PROTEC.-COV x2
B33.10.7.505.602 SHAFT SEAL x2
a new key fob case, like this, for a 1989 E30 325i touring reg H20 RDV:
http://media.photobucket.com/image/bmw% ... alarm2.jpg (sorry, i can't find the part number)
and finally a full car set of the plastic trims clips for the plastic trim that sits over the bottom of the rear door seal, item 11 on here:
http://www.realoem.com/bmw/showparts.do ... g=40&hl=13
cheers
i can't work out exactly what's required.
cheers
Cotswoldbmw
Hi There
B33.12.1.200.284 PROTEC.-COV x1 £1.31
B33.10.1.214.099 OIL SEAL x1 £10.90
B33.12.1.744.368 CLAMP BUSH x1 £5.06
B33.13.1.208.006 PROTEC.-COV x2 £1.16 for 2
B33.10.7.505.602 SHAFT SEAL x2 £20.07 for 2
remote case £4.51
clips bag of 20 min qty £3.93 for 20
Prices inc. VAT delivered to mainland UK
Please call us on 01242 257999 and quote 13305
This quote is valid until the end of the year as we are due the VAT increase
There is a P&P cost of £1.99 on all orders under £20
Brett
remote case £4.51
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
gareth
Payment sent via bank transfer (should show up as coming from from Mr G Purves)
I've put the 13305 reference in there and it should be there within 2 hours.
Can you let me know if/when it's arrived?
Gareth
Gareth
Cotswoldbmw
Payment recived, parts ordered will be with us Tuesday, we will send out Tuesday
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
gareth
fantastic, cheers!
mince pies, plenty of drinkypoos and a diff to rebuild over christmas. perfect
