Parts for my Rebuild
Looking for genuine BMW parts at discounted prices? Try here!
Andy325i
Post Fri Mar 14, 2008 3:36 pm
Hi Paul, could I have prices for the following please:
The bracket that holds the rear bumper side piece in place (circled blue) and the (2?) bolts and nuts that hold it in place
The white plugs that go into the door/rear wing to hold the black buffer strips in place (circled red) I think there are 4/5 in the door and 3 in the rear wing?
and also the black buffer strip for the door, I already have the 51 13 1 965 105 one you sent for the rear wing :D
and the clips that go into the back of the trim itself (for both door buffer and rear wing buffer)
Lastly inside the car, on the inside of the B pillar at the top, the black trim piece that goes approx the height from the bottom of the window to the top of it and has the hole on it for the top seatbelt bolt. This trim is a very thin piece(front to back), and approx 2 inches wide
Details Pm'd over
Many thanx
Andy
zimmerbimmer1
BMW Parts Meister
Post Mon Mar 17, 2008 10:18 am
Hi Andy,
The Bumper Bracket £5.70 per side
There is a few clips please see link
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
with regards to the bufdfer strip could you please confirm the part you already have is the correct style
Andy325i
Post Thu Mar 20, 2008 2:52 am
Hi Paul,
The buffer strip you supplied for the rear wing is the same style as on the car :D Please could I have the matching one to this, but for the front door
Here are the clips:
Front of Door:
2nd and 4th clips on door:
Center of the door clip:
And at the rear there is a hole for where a metal pin comes out (now lost somewhere in the door!)
I think the middle clip on the rear wing are the same type as the 2nd/4th/ center ones above, so will need:
1 x front clip
6 x clips in second pic
2 x gromets in third pic, each side of the buffer strip clip (center door) (These hold a support bracket behind)
and the rear clip that has the metal pin in it (right at the rear of the door as hole is shown in 4th pic)
Next for the rear wing buffer strip there is a clip at the rear of it that slides into the rear of the trim piece as shown:
It goes here on the trim:
and the two grommets in rear wing to hold in place:
The N/s bumper bracket please (+bolts/nuts for it etc)
Also the piece of black trim that goes on the top half of the B piller, inside the car (VERY thin piece of plastic with hole for seatbelt top mount iirc)
and the three clips that go into the C pillar that hold the hockey stick in place between the rear side window and the rear screen on the outside of the body.
Sorry for the long post! :o:
Many thanks
Andy
zimmerbimmer1
BMW Parts Meister
Post Wed Mar 26, 2008 11:36 am
Front clip £0.26
6 clips £0.26 each
Grommets £0.14 each
The metal pin only comes as part of the moulding :eek: :cry:
The clip on the rear moulding only comes with the moulding :cry:
B post trim £14.86
Bumper bracket £5.70
C post clips £0.26 each
