C101 & C104
Looking for genuine BMW parts at discounted prices? Try here!
Ziggy
Tue Jan 22, 2008 10:30 am
Tiny bits today please!
C101 pins x4 (I think it's pins rather than sockets anyway) for the body side of the plug... I only need 2, but might as well have a couple of spares as well!
C104 plug/socket - to connect to this one that's under my dash (as in I need the engine-side connector)! Image
If it doesn't come complete, I'll need the pins too :)
& the connector for the fan temp switch on an E28 M535i radiator!
Cheers,
Jon
zimmerbimmer1
BMW Parts Meister
Tue Jan 22, 2008 11:18 am
you like to make me work don't you
:lol: :lol:
Ziggy
Tue Jan 22, 2008 11:19 am
:o: Sorry!
Ziggy
Tue Jan 22, 2008 11:29 am
I expect the C101 are on here - don't know the size off the top of my head though!
http://www.realoem.com/bmw/showparts.do ... g=12&fg=31
Ziggy
Tue Jan 22, 2008 1:10 pm
Still struggling?!
If you have a(nother) mo, could you manage a price on a long battery cable (E30 325i 2-door) suitable for re-locating my battery to the boot? & an 325ix washer bottle? Expect I'll be better off finding those second hand, but worth a try!
Cheers :)
zimmerbimmer1
BMW Parts Meister
Tue Jan 22, 2008 3:19 pm
The C101 pins 51p each is it the male or female you require?
Could you send me a pic of the C104 connector showing pin layout
may be its me being thick my system does not show a sensor in
the rad of a E28 M535i.
Battery Cable £60.30
325ix Washer Bottle £40.24
Ziggy
Tue Jan 22, 2008 4:01 pm
The sensor's just to switch the electric (aux/aircon) fan on... Only spade terminals though, so hardly a big deal.
I can't remember if I need male or female pins, so 4 of each'll do just fine...
Does the pic above of the c104 work? I know it's rubbish, so I'll take a better one if you need it!
edit: slightly better one from elsewhere: Image
As I expected, I'll pass on the bigger bits for now! :)
Ziggy
Tue Jan 22, 2008 4:16 pm
There's more explanation & a basic diag of what the c104 is, here (just click the c104 tab at the bottom)... http://dbrt.id.lv/C101_Pinouts.xls
Ziggy
Tue Jan 22, 2008 11:18 pm
Paul,
I also need some fusebox connectors - 2 fuse ones and 4 relay ones (need to add a fuse & relay for my electric fan) :)
Don't worry if you can't work out the C104 & rad connectors - I can use bullet/spade connectors for them. Could do with the C101 & fusebox ones before the weekend though ideally, so if there's a chance you can get them posted tomorrow, there's more chance I'll be driving the E30 with the M30 in it at the weekend! :)
zimmerbimmer1
BMW Parts Meister
Wed Jan 23, 2008 10:10 am
do you know what size the fuse box ones are?? I can order for tomorrow and post to you for fri/sat :D
Ziggy
Wed Jan 23, 2008 2:04 pm
Um... no! I thought they were standard tbh! Will have to see if anyone knows in the tech section I s'pose... :?
E30Mark
Thu Jan 24, 2008 12:24 pm
Ziggy wrote:Still struggling?!
Cheers :)
Chris_W is advertising a complete battery re-location kit on his parts page...
http://www.chriswarburton.co.uk/parts.htm
PM for details
Ziggy
Thu Jan 24, 2008 1:21 pm
Guess he's either got more than one, or that'll shortly be removed... Should currently be winging its way to me with the fly, some C101 pins & a fuseboard to butcher! :)
So Paul, don't worry about trying to work out what I need!
Jon
zimmerbimmer1
BMW Parts Meister
Thu Jan 24, 2008 2:11 pm
OK Jon,
Glad Chris-w sorted you out
Regards
Paul
