Some S50B32 bits
Looking for genuine BMW parts at discounted prices? Try here!
tomson
Post Thu Jan 10, 2008 12:09 pm
Hello Paul,
prices on the following please
Set of 8 S50 flywheel bolts
4 S50 main cap bolts
S50 880mm aircon belt (part no 11281402334, Thanks Ian)
S50 altenator belt
Pair of E36 rear gearbox rubber mounts
E30 brown temp sensor
Pair of E30 tie rods (the bar bit :mad: )
Pair of E30 track rod ends (the ball joint bit :mad: )
Thanks mate
Tom
zimmerbimmer1
BMW Parts Meister
Post Fri Jan 11, 2008 11:23 am
Hi There prices as follows
Set of 8 S50 flywheel bolts £10.49 for 8
4 S50 main cap bolts £2.00 for 4
S50 880mm aircon belt (part no 11281402334, Thanks Ian) £13.87
S50 altenator belt £21.86
Pair of E36 rear gearbox rubber mounts £16.76 (pair)
E30 brown temp sensor £13.05
Can get complete tie rods £63.22 each
quote reference number 56609 when ordering
:D :D
tomson
Post Fri Jan 11, 2008 12:51 pm
zimmerbimmer1 wrote:Can get complete tie rods£63.22 each
Eek!
How much are just the balljoint end's then as i can rescue the bars from a spare rack I have?
Also need these please,
E30 heaterbox to bulkhead gasket
M coupe diff backplate gasket and a pair of copper washers for the plugs
